Does the RT Limited come with a swaybar or is there not one there to begin with? If there is one, anyone have a pic of the two side by side, not sure what the difference is. New owner of course.
Printable View
I think he wants to know, if there is a stock one, what's the difference between BajaRons bar, and the stock one. BajaRons is heavier built and supposedly stronger to help prevent "roll" in the corners, and other benefits too. I still haven't had a chance to try mine since replacing it....but I did the replace in my 2010 RT I had and it did make a difference
Precisely, just trying to figure out if the spyder that I have has a swaybar already, what I'm getting by getting another one. I thought a side by side comparison between the stock swaybar and the Baja swaybar would give me a clue as to if its worth spending my money on or not.
I'm not cheap, but I am somewhat "tight" I see people say that it improves the ride but seems that a lot of people stick with the stock bar as well. So kind of on the fence yet.
ALL Spyders come with a sway bar!
No pic but the Baja is about twice as thick.
The new links are metal and move as they should; the stock are really tough to move.
Believe the 1000s that have made the switch.
You will not regret it and the easy it brings to manuevering with a proper alignment of course!
AJ
I consider myself frugal which my wife translates as World Class Cheap! Nevertheless, I popped for a BajaRon bar installed by the dealer as part of the OTD package. Looking at an OEM bar and Ron's you will ony be able to see the latter is larger in diameter but you can't tell just looking how much better it will make your Spyder handle. Life is short, pop for it and have more fun!
The ends - are "metal" ? Not according to Baja Ron - the ends are now aluminum.
Speaking of BajaRon: He's the guy who is most likely to have some side by side comparison pictures of the bars... :2thumbs:
See if he'll post them for you!
