Are you sure this is not vibration coming from the belt?
I did have some minor vibration prior to changing tires, but it's definitely worse with the new tires. The vibration is such that when I put the cruise control on and remove my hands from the handlebars, the bars shake like crazy. The bike still tracks OK and at lower speeds it's fine. I'm taking it back into the shop tomorrow or when they have an opening and have them look at it before I do anything else. I did look for weights and they are in place and look to be new. Also played with pressure a bit ... I have 18psi all around (as was suggested), that goes up to about 21 when hot. I'll mention the belt, but it sure feels like it's coming from the front tires. Thanks for the ideas!! I'll follow up when I know more.
Can you see a Red or Yellow dot on the tire sidewalls anywhere?? :dontknow: IF they're there, they're usually low down close to the bead, and if the tire's been mounted properly, should be near the valve stem or near a raised metal dot, a notch, or a marked spot on the edge of the rim where it's been marked indelibly to identify where to align those paint dots... ;)
If you do have those dots on the tire sidewalls, and they are nowhere near the valve &/or a clear mark/dot/notch on the rim edge, then it's likely that the tire hasn't been mounted correctly and so may be more prone to balance &/or run-out issues... :rolleyes: The bad news is that on many of the 'better made' tires out there, they don't have any noticeably heavier/lighter spots &/or run-out to mark, so not all of the better quality tires will necessarily have any paint dots; and on the other end of the scale, many of the cheaper/lesser quality tire manufacturers are now aware of this, so they've stopped marking their tires too, despite the fact that their tires clearly DO have heavier/lighter areas &/or run-out areas too!! :mad:
So unless you're tire/wheel assembly tech was switched on and did the job properly, the only sign you might ever see/feel that indicates you've got an issue may well be a bad vibration from the wheels... :gaah:
Just Sayin' :rolleyes:
If you have handlebar shake it doesn't have anything to do with Belt Vibes or the air pressure ..... IMHO, I doubt Can Am dealers are going to spend money on a Spin Balancing machine (they are not cheap), because they won't have much use for it ..... They will take them to the nearest cheapest Auto tire place, pay them to do it instead, & just charge you triple what it cost them. :roflblack:
Back when BRP was still making the V-twin engine, they would tell the owners that a VALVE CHECK (for clearance adjustment) was necessary at 28,000 mi. +/- (at a cost of about $850.00).... Here, we figured out that those Valves weren't going Out of Adjustment until way over 100,000 mi. (if at all!) .... I have wondered how many owners paid to have it done and the Valves weren't ever checked at all???? :dontknow: ..... JMHO .... Mike :thumbup:
I took the bike into the dealer yesterday. The tech rode it and gave me the run around about not knowing much about my particular bike and how it rode but did not feel any appreciable vibration in the handlebars. Anyway, I disputed this conclusion and they will re-balance the tires as soon as their balancer is fixed in a couple weeks (waiting for a circuit board replacement). He also commented that there was no "dot" on the Vredestein tires for mounting at the valve stem. That kinda tells me that could be a potential problem. Does anyone out there with these tires know if there is some symbol or ?? indicating where the tire should be positioned on the wheel?? Also, before anyone bad mouths the dealer ... I've bought 4 motorcycles over the years from them and I've known the owner for 25 or so years and never have had an issue with their service. I'm confident that if these Vredestein tires will work on this bike without a balance/vibration issue, they will do everything possible to make it happen. If they can't, I'm having them save the old Kenda fronts and put them back on as a last resort. They were still in good shape; it was just the rear that needed replacement, and I don't think the Altimax would be the problem.
Vredesteins apparently DON'T have the DOTS because Vredesteins may not need them ( according to Vredestein ) ..... " as soon nas their balancer is fixed " !!!!! this should:thumbup: be a clue ..... .....In all my years of buying tires I've never had one that couldn't be balanced .... some have NOT even needed weights .....Mike
Yeah, as I mentioned earlier, "The bad news is that on many of the 'better made' tires out there, they don't have any noticeably heavier/lighter spots &/or run-out to mark, so not all of the better quality tires will necessarily have any paint dots..." and the Vredesteins are widely recognised in the industry as falling into this category... somewhat more so than the Altimax!! :lecturef_smilie:
And that's ^ what the paint dots are for, but on tires made by Vredestein & other similar quality brands, they're generally only there IF IT'S NECESSARY to identify any specific positioning. So any 'potential problem' most likely isn't going to be the tires themselves - if 'they' can't balance a set of Vredesteins, it's fairly unlikely to be the tires, they are generally made so well that they don't need any special positioning on a well-made & round rim to achieve a good balance... However, there are also rims out there that aren't necessarily all that well balanced too... But a good tech knows how to and generally compensates for anything like that which can/should be corrected for while doing the balance job anyway, and if it can't/shouldn't be compensated for, they'd tell you. Altho that story about the balancer not working is a bit worrying - if it's not working now, how did they actually balance your tires earlier?? :rolleyes:
Both my Federal and Vredestein tires I have were not balanced at installation and run pretty smooth on the road. I did buy front centramatic wheel balancers just to assure they we running to best they could. They are on the Asphalt Grey trike right now with the PPA wheels and Vredesteins. May move them to the Champagne trike for the ride from Az to Wa with the OEM chrome wheels and Federal Formoza tires. The H&R springs are on the way for that trike, and I will put the Asphalt Grey one in storage and start riding and servicing the Champagne one for the next month and a half to assure it is ready for the 2000 mile trip.
