Originally Posted by
BLUEKNIGHT911
....Mr. Humphreys, because I am not a " BUM " I will take the time to help you understand a few things about measurements ........But first let me say that my figure # .0005 % was just an EXAGGERATION and you have my apology for that.........However I think you were rude to say I was/am a BUM and lets leave RELIGION elsewhere OK.........I happen to have BOTH tires in question in my garage a Hydro edge 215 /60-15 & a 225 /50 -15...........I measured them side by side and you are correct the difference is approx. 1 in.........But when you mount them and put them on the Spyder it will only change the height by 1/2 in because only 1/2 inch is below the axel,,,the other 1/2 inch is ABOVE the axel and this has nothing to do with elevating the Spyder.................Plus this will only RAISE the rear of the Spyder , not the front .......To get an accurate change in the CENTER OF GRAVITY ........do this ---take two car jackstands and place them 5 1/2 ft apart ( this is the wheelbase of the Spyder + - )......now take a something 6 ft long that won't bend like angle-iron......place it on the jack stands......measure in the middle down to the ground ........now place something 1/2 thick on one of the jack stands under the angle-iron .....and measure again in the same spot ......this will give you a number that more closely reflects the CHANGE IN THE C.G. ,........How much do you think this change is going to be ??????..........I'll tell you ....It's now 1/4 inch .....Do you really think 1/4 inch change in the C.G. is going to affect the handling of your Spyder ? ? ?........................and as far as the weight thing goes at 500 lbs I think this has exceeded the what BRP recommends for the Spyder but that's for you to decide ...........................Even at that weight the springs either OEM, or ELKA , or FOX etc. are ( to best of my knowledge ) PROGRESSIVE RATE springs ......meaning they get STIFFER the more you compress them ...........So even at 500 lbs the height change in your Spyder is not as much as you might think............Your welcome .......Mikeguyver :thumbup:
