I am changing out my Kendas for the Quatrac and would like to know if they are a directional tire or not?
Also, for those of you using Ride-On, does it come in measurable bottles for 3 oz per tire?
Thanks in advance for the info.....johnv
They are directional.
Yes they are a directional tire. I can't comment on Ride On as I don't use it.
Side wall will show direction of rotation if directional
for a 165/60/15 is 10 oz
If this tread pattern, then yes.
This has been asked before .... I don't think they are , I have the Quatrac 5 and there aren't any Arrows on mine .... I checked the Tire Rack site and didn't see any arrows on the NEW Quatrac model either , however that Tread pattern looks directional .... Mike :ohyea:
I prefer the Car version of Ride-On in the Spyder. Which makes sense because we are running car tires/wheels and not motorcycle. It is less expensive and works better for balancing than the motorcycle version. You will need 2 bottles to do all 3 tires. However, if you have an out of round tire (a problem with OEM Kenda's) Ride-On can exacerbate that problem.
The Quatrac is definitely directional. They had a highly stylized arrow in the past. But you're right, I don't see any arrow on the current version. But no matter, it is a directional tire.
As per Vredestein, "The Quatrac features an all-season tread compound molded into a distinctive, directional, v-shaped pattern."
I am installing just the fronts, how much sealant per tire?
Thanks johnv
Here is a link for the official Ride-On dosage calculator.
https://www.ride-on.com/us/calculator
The Quatrac 5 is a non-directional tire: https://www.vulcantire.com/tire_deta...c5_s.htm_22032
The Quatrac like I have is a directional tire: https://www.tirerack.com/tires/vredestein-quatrac
Anyone used Ride On in their back tire? How do you think it performed as far as balancing?
I've used both the Car and Motorcycle Ride-On in all 3 tires. I much prefer the Car version for balancing. I'm told the Car version is not quite as good at sealing as the motorcycle version. But I was more interested in balance than sealant. And though I've never needed the sealing attribute, I believe it would seal just fine. A motorcycle tire has much less air volume than a car tire so sealing quickly is more important on a motorcycle. Not to mention, a flat on a Spyder isn't all that dangerous. Whereas, a flat on 2 wheels is VERY BAD!
Motorcycle tires have much less mass than car tires. So they are easier to balance, which is why the motorcycle version of Ride-On sacrifices some balancing ability in favor of quicker sealing.
I've been very happy with the Car Ride-On. If the Spyder sits more than 2 weeks, I get a bit of out-of-balance for the first 5 miles or so. Then everything evens out and the ride is smooth again.
I can't say enough good about Ride On. When I first heard about it I thought it was all BS but after trying it I am a believer. I first heard about it from an old school Harley mechanic. I was putting a new tire on my Harley and needed some tire weights, so I called him to see if he had any. He said he did, but told me to try Ride On instead, which I did. He was so old school that if you wanted synthetic oil in your bike, he would not service it. He never serviced mine for that reason.
Just went to the Ride On website and they said they were out of stock of their auto/suv packs but had a button where they would notify when back in stock.
When you use Ride On are you supposed to remove all the wheel weights?
I've been using Ride-On sealant in my m/c tires for years. I had a nice talk with a Ride-On technician about which formula to use in my Spyder tires. He was very specific about these two points:
1.) He insisted that I should use the motorcycle formula even though I had car tires installed. He stated the m/c formula was preferred over auto formula in trikes.
2.) He also was adamant that I use the standard dosage versus the severe dosage amount.
I've always had good luck buying the "dented/damaged" products direct thru Ride-On. Never received any unusable product.
Copy/paste
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://images.ride-on.eu/en_US/dosage-table/Motorcycle_Dosage_Table_and_Installation_Instructi ons.pdf
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.ride-onshop.com/auto_version_14.0.pdf
Did he give you a reason why? I've talked to them as well and I could never get them to explain why or give any reason at all that a car tire should get a motorcycle tire product. They just kept telling me to use the motorcycle version. With detailed information on everything else they say, I find this odd. More of a mantra than fact based advise. Which, on the face of it, makes no sense at all.
I also asked them why they originally (for several years) recommended the Car tire product for the Spyder, then suddenly changed their mind. Couldn't get an answer for that either. My feeling is it's a CYA approach. Our OEM tires say 'For Motorcycle Use Only', which BRP made a big deal about right around the time that Ride-On had a change of heart. My feeling is that Ride-On doesn't want to go to court over it. Plus, most trikes have a motorcycle front wheel (which I agree, should get the M/C formula).
I've tried them both and I prefer the car tire formula in the Spyder. If Ride-On would give a coherent, rational reason for using the motorcycle formula in a car tire, I would be happy to reconsider.
I've never heard of "ride-on" but maybe this would solve my vibration issue. I just had Vredestein's installed in front and Altimax 45 in the rear. The service tech swears he balanced and aligned the fronts, but I have a noticeable vibration starting at 55 and getting worse up to 70mph. Would this "ride-on" fix this if the tire(s) are out of round or ...???
check your front lug nuts to be sure they are tight
Auto tires ( ANY Brand ) are Rarely un-able to balance ..... Are there people who don't know how to balance ....IMHO this is more likely ..... Take both front wheels to any Auto shop that balances using a Spin balancer and have them check it ..... good luck .. Mike :thumbup:
Did you ever get them to smooth out? If they were out-of-round, a product like Ride-On can actually make it worse.
He is right that the M/C formula is less viscous (more liquid) than the auto formula. This means it will even out sooner than the Car version. But it will also give you an out of balance situation after sitting much more quickly then the Car version. Kind of a tradeoff I suppose. But the bottom line is, the car version will give you more balancing potential than the M/C version. If you don't need much balancing, then maybe the M/C version will work just fine. But you won't know until you try it. It may also be that the M/C version won't exacerbate an out of round tire issue.
But if you have an out-of-round tire, don't waste your money on Ride-On or dynamic balancing, for that matter.
I agree. It is unlikely that the tires are the problem. How much weight did they add to the wheel? Does it look like new or old weights? Those tires almost never need that much to balance.
Did they line the valve stem dot up with the valve stem? This is your first indication as to whether or not your tech did a good job. It doesn't need to be perfectly aligned. But it should be close. Sometimes the tire will move a bit on the rim during mounting and it's not worth the effort to get the dot right on.
Be sure the wheel lug nuts are properly torqued (as already suggested). I would eliminate all other possibilities before putting Ride-On in. If adding Ride-On doesn't fix your issue, it may complicate finding a solution.
