Originally Posted by
effgjamis
thanks again to all.
As to the seat... It is ok, much better than the one I had on the RS, however the one on the RS was off the shelf, This one they spent the day doing a fitment for my butt. It fact I will give it an A+.
A couple of issues.
1. They do not provide a means of holding the seat up if you find it neccessary to check brake fluid and to retreive your battery tender cable or if you need to charge or jump start.
2. The stitching on the seat leaks water... Now I need to fiind to waterprofing to fix that.
I highly recommend, if you go Corbin, to go to the factory and have it fit to you, well worth the stop since I was fairly close.
Yeo it is A+
