I struggle with taking my mirrors off every time I have to. I am sure looking forward to getting both sets that I ordered. 1 set for my wife's RT and 1 for mine! Thanks Russ for making this possible!:yes::yes::yes:
Printable View
I thought I would pass this on .....I do not own a 13MM deep well socket, so I found that a 1/2 inch deep well socket (thin wall) worked perfectly to remove the 3 mounting pins on each side.
The install went great and was super easy! Time will tell if they hold the mirrors through all the bumps, vibrations, etc.....seem to hold them on tight. Package contained the "perfect" amount of parts which is always great.
I must confess......I utilized this video more than reading the instructions! :opps::opps::opps::opps:
https://www.youtube.com/watch?v=YS-RUcow91s
Package arrived today from Australia. Thanks Russ. Installing later this week.
Hey guys, how do I best get this across?? :dontknow: Let's try this way..
You
REALLY
DO NOT
need or want to use locktite on the screws holding these magnets on - if you do, there's a very good chance at some stage down track you'll not be able to remove them again without destroying the Phillips head on the screw, or if you've left the screws in place long enough, maybe even having to drill them out to remove them!! Your Spyder is not a Harley, it doesn't vibrate everything apart! These screws WILL remain firmly affixed if you 'just nip them up only' as per the instructions, & then DO NOT OVERTIGHTEN - OR USE LOCKTITE! :lecturef_smilie:
While the screws themselves are 'less magnetic' than plain iron/steel due to the material they are made of, they are still somewhat capable of accepting a magnetic field, especially if you leave them there over time (as you will) & the magnets are pretty damn strong!! So by just running the screw thru the magnet & into the plate behind it, effectively only finger tight, ie 'just nipped up' as per the instructions, it allows the magnet to fix the screw in place a fair bit harder than any of the normal blue locktite or 'screw fix' stuff you might use anyway - but then by adding some 'real' locktite & then leaving it there for a while as well as letting the magnetism do it's thing & also letting a bit of oxidisation get to work on the metals (as it invariably will) it is very likely to bind the screw in place far better than leaving it swimming for 20 years in a saline bath!! :shocked: So if you want to create real problems for yourself down track, just add some locktite to the magnet holding screws! :yikes: :gaah:
So I'd stongly suggest that anyone who HAS used locktite on those screws holding the magnets in place goes back & cleans the locktite off with the appropriate solvent; because it doesn't take a heap of time for the locktite to set hard/tight & then not much more for the magnetism & naturally occurring oxidisation to develop enough that the phillips head screw will become impossible to remove without stripping the head & making it necessary to drill the screw out!! Note, I used the word IMPOSSIBLE in there on purpose; not 'difficult'; not even 'a right pain in the arse', but IMPOSSIBLE!! :yikes::yikes: Anyone want to ask me how I know??! :gaah::gaah:
So.... how else can we make this absolutely clear to you all? :dontknow::gaah:
You do NOT need to add any locktite to the magnet holding screws, & if you do, you WILL be fixing those screws into place pretty much permanently once everything's set & some time has passed, which could be a major problem down track if you ever need to remove the tupperware or the lights!! And besides, if you keep all the bits you remove & follow the Magic Mirror instructions for fitting (without adding Locktite), then if you happen to sell that Spyder down track some time, you can always whip the Magics off & replace the OE stuff so you can transfer your Magics on to your next Spyder!! Win/Win!! :thumbup:
How about:
The Loc-Tite goes in here:
nojoke
Watch out on that top magnet! The magnet diameter is large enough that it WILL sit on top of the tupperware tab. If you tighten it too much you will cock the magnet and then it won't make proper contact with the plate on the mirror body. In Russ's video he says the tupperware must be just loose enough to move under the magnet. This is the tab where you take the screw out, toss the washer, and reinstall with the tether loop under the screw.
I thought there was an interference issue and was about ready to cut the tupperware tab back but I decided to watch his video again.
This is what it looks like.
NOW is not the issue - besides, the only 'unforseen issue' that is quite likely to occur if you've added locktite is that some months or even years maybe(?!) down track when the screws have been in place for a while & they are not only held in very firmly by the magnets (differently certainly, but probably even firmer in the first place than if you were using locktite alone on a screw with no magnets involved) & some oxidisation has occurred (as it will!) & you find you need/want to remove the tupperware or headlights only to discover that there is now absobloodylutely no way to get those screws out without stuffing the heads or by drilling them out... :rolleyes: :p
But yeah, you are completely correct, you can do as you wish, & adding yet another ounce of prevention on top of the already 'more than sufficient' gallon of prevention that's been designed into the product can't possibly hurt... can it?? :shocked:
Just don't ever complain that you weren't warned!! :sour: :banghead:
thats right
after you nip up the magnet,the tupperware tab should(will) still move. we fitted up a dozen magics at the muster on the weekend and all tabs were free. if the tab is trapped the magnet cant sit flat. this is why we remove the washer too. also the reason for the black spacer:thumbup:
Just back from our annual muster (around 50 RT'S) and fitted around 12 kits.As things were getting a little hectic what with magics and wheel alignments,some buyers did their own installs and we in the know checked over them at the finish.Here are some mistakes that were made (no one was using eddys system or reading the instructions)
1. the mirror didnt close
we found the top tab washer had been left in place....if you follow the instructions it says to remove the top washer first.Then having done one side,you move to the second mirror and its all getting a bit rote.So we dont need to follow the instructions anymore and we forget to remove the washer first...i will amend the instructions to say"first remove both mirrors....then remove both washres".....
2. we checked one fitters R.I.P. bag after the install and found......one steel tab washer and one black spacer:gaah:.......he had placed the steel washer he removed from the tab, under the magnet instead of the black plastic spacer...he put said steel washer in the worst possible place..under the top magnet
obviously the tab would have been trapped had he checked it, as the black spacer is thicker than the tupperware tab but the steel washer is not
lesson is to be tidy and organised and when finished to check the parts left over....should be 6 plastic receivers oem,6 steel pins and 2 steel washers in the bag:thumbup:
3.buyer presented with assembled magnet on the screw ready to fit to bike
unfortunately when he read the part which mentioned the white washer first, he decided to use one of the white spacers which are between the magnets instead of the small white washers supplied in the packet:gaah:...maybe watching the vid as per eddy would have preventd this....the magnet spacers are to be discarded and do not figure in the fitment
4.degree of difficulty when closing mirror......buyer had previously self fitted blinker repeaters,a line of LED's on the glass.unfortunately he had used scotch locks instead of neatly splicing the wires into the loom..scotch locks are cumbersome and bulbous so when he tried to shove the wires up the mousehole,the 3 connectors didnt want to go in.......he was asked to go home and tidy up his wiring:roflblack: the mirror did close but it wasnt clean
5. when fixing the petals the fixer didnt wind the mounting screws in far enough resulting in the screw head sittin above the top of the petal. the magnet now cant sit flat on the petal resulting in inferior attraction
remedy....ensure both mounting screws are fully tightened when mounting the zinc plated petals(receivers)
in spite of these faults it was a very enjoyable experience but it does highlight the need for vigilance. sometimes its as well to work with a friend so as to check each others work...as long as that friend is not jack:roflblack:
thanks russ
I was going to place an order for a set of the mirror magnets but a note was added to the description stating that the "tether" will no longer be included. :dontknow: For those of you that have already installed these mirror magnets do you feel that a safety tether would still be necessary? Not sure if we are supposed to still use a safety tether but have to make them ourselves. :shocked:
Nothing in my mail box today. 15 days and counting...
Russell -- mine arrived today (order #960) if you are keeping track of deliveries.
I am in the midst of a major teardown of the Fat White Chick, so it will probably be late this week or next before I get them installed.
Cheers, Paul
guess who a happy pup :yes::yes:got my today #1042
Order 992 Upstate NY (above Bob D, sorry Bob!) even with a screwed up address (but right zip)
Here today!!
I'm not getting on YOUR case in particular about this Trikermutha, & I'm happy for you if you want to do your own thing for whatever reason, but it is important that people OTHER THAN YOU realise that while you can stick locktite on these screws now & have absolutely no issues with them NOW (as you keep telling us) or possibly even in the short term, but because the magnets are already doing the job that you would normally use locktite for AND we've added dissimilar metals plus a magnetic field to mildly enhance the potential for a reaction, it almost certainly will create removal issues for them sometime down track - probably not just in a few weeks; possibly in a few months; very likely by 6-8 or so months; almost certainly in a year or so's time!! Still, it won't be a biggie if it's just bare metal & magnets holding them in, but add locktite & it's more than 'just' overkill... it almost certainly IS gonna be an issue.... :gaah:
So it may seem TO YOU that I'm belabouring the point, but I'm really only trying to stop others from making the same mistake & creating a whole world of bother for themselves. :lecturef_smilie: Sure, you and anyone else who wants to can make any foolish mistake you like, ignore any reasoned advice you like, do whatever you like, but I really don't want anyone to make an unwitting decision based upon the premise that 'adding Locktite can't create any problems' when I know from bitter & painful experience that in this particular set of circumstances IT CAN!! :dontknow: As soon as everyone (&/or anyone) stops posting about how they think it WON'T hurt in a way that might encourage others to do the same, despite the 'testing' that suggests it will, then I'll stop warning all the other readers out there. :rolleyes:
Happy to move forwards.... ;)
WORD !! ^^^ ;)
After all, Peter is only speaking from experience. :)
