Thanks!! Ended up using a bit of wd40 and let it sit for an hour or so then tapped the broken arm down with a hammer.
My biggest issue is that one of the pins got damaged and wouldn’t slide back in, so I’m running the arm with one pin. Hopefully that’s not too bad. Other then that, it goes up and down no issues.
Glad to see you managed to get the old one off and the new one on. I'm not sure about replacing the pins, maybe you can find someone nearby that can machine you up a couple
