have to agree, no Tacoma has a CVT. some Corollas and Priuses have them, Not a Tacoma
Printable View
How about this accessory: a seat attachment that is a mini trunk (big enough to cram the wifes purse in), put a helmet lock on there somewhere and add a cushion to it so it can double as a back rest.
BTW: ALL Spyders/Rykers should have SPORT mode available on them. :pray:
She wants the Ryker Rally with Army Green, Sport Shield and Splash Guards.
There is? :shocked:
I must have missed that option; while building the three that I tinkered around with! :banghead:
Thanks for the info! :clap:
The Ryker reminds me of the Sportster and Harley. The low price may get people into riding three wheels and soon after they will want the extras of the F3 or RT. Not a bad plan. I would like to see the driveshaft migrate to the F3's and RT's.
Honda better get their rear in gear if they have any thoughts about getting a piece of the three wheel market. Good grief Honda, throw a front end on that 1800 Goldwing and call it a day!
BRP does it again!!!
actually, its even uglier than F3 and more stuff I added, windshield/saddlebag, worse it looked.
I shall take good care of my 15 RS, hopefully long enough for BRP or other manufacturers to come up with a replacement.
its just my opinion and doesn't make it right or wrong, just not for me.
After some time thinking about it... I think the real money for can am to make is in all the accessories/accessorizing that people will want to do to their Ryker to make them their own. It's brilliant really.
I am sure that you have all realized this by now
So I finally got to watch some videos on the Ryker.... It looks like the designers took the batman motorcycle from the Dark Knight, made it into a y-frame tryke and put Darth Vaders Face on it. Not sure if I love the looks or hate them but I am pretty sure there is no in between.
Here is the entire spec list, sans the individual group headings, from the Build It page.
Download spec sheet
Type Rotax® 900 ACE™ in-line 3 cylinders, liquid-cooled with electronic fuel injection and electronic throttle control
Bore & Stroke 2.9 in. (74 mm) x 2.7 in. (69.7 mm)
Power 77 hp (57.5 kW) @ 7100 RPM
Torque 56 ft-lb (76 Nm) @ 6300 RPM
Type Automatic (CVT)
Reverse
Front Suspension Double wishbone
Front Shocks Type / Travel KYB HPG with preload adjustment 36mm / 6.38 in. (162 mm)
Rear Suspension Multi-link - mono swing arm
Rear Shock Type / Travel KYB HPG 40 mm with remote reservoir 4-positions compression adjustable damping and preload adjustement / 6.89 in. (175 mm)
Electronic Brake distribution system Foot-operated, hydraulic 3-wheel brake
Front Brakes 270 mm discs with Nissin 2-piston floating calipers
Rear Brake 220 mm disc, 1-piston floating caliper
Parking Brake Park lock
Front Tires MC145/60R16 66T
Rear Tire MC205/55R15 81T
Aluminum Front Rims 5-spoke Carbon black & Machined, 16 x 4.5 in. (406 x 114 mm)
Aluminum Rear Rim 5-spoke Carbon black & Machined, 15 x 6.5 in. (381 x 165 mm)
RIDER CAPACITY 1
STORAGE CAPACITY 1.85 gal (7 L)
TOWING CAPACITY N/A
FUEL CAPACITY 5.28 gal (20 L)
FUEL TYPE Premium unleaded
L x W x H 92.6 x 59.4 x 41.8 in. (2,352 x 1,509 x 1,062 mm)
Wheelbase 67.3 in. (1,709 mm)
Seat Height 24.2 in. (615 mm)
Ground Clearance 4.4 in. (112 mm)
Dry Weight 627 lb (285 kg)
Type 4.5" digital display
Main Functions Speedometer, tachometer, odometer, trips, gear position, distance to empty, engine lights, fuel gauge, clock, ECO mode, Sport mode and Rally mode.
Audio System N/A
SCS Stability Control System
TCS Traction Control System
ABS Anti-lock Braking System
DPS™ N/A
Anti-Theft System Digitally Encoded Security System (D.E.S.S. ™ )
HHC Hill Hold Control
Factory 1-year BRP Limited Warranty with 1-year roadside assistance
Extended BRP’s B.E.S.T. extended service term available from 12 to 36 months.
Whats Not to like-
Easy access to rear tire replacement and Spark Plugs , Battery, and coolant ! Little slot car that's going to replace my F3 and cost me nothing in a decent deal! Sport front windshield will probably need the touring shield on top But its a No Brainer for me who rides only in my own State with no long trips. Gas mileage on the ACE 900 is excellent on the Spark and probably much better than the 1330 in my F3? Just want a test drive?nojoke
100% agree!!!
BRP is on the right track in a lot of ways with this, but the styling definitely needs work. The F3 grew on me, but still is not appealing to say the least (In my opinion).
Lots of comments about the F3 looking like a lawn mower with the Ryker on the same page is funny, because when I had my wife at the dealer the last time she commented that the F3 looked like a lawn mower at the time a just laughed. Funny seeing other people think the same!
One thing for sure and Harley has this problem too is not everyone likes the mid mount or forward pegs. I prefer more of a sport position with the peg pulled back more from the mid point, I can't see if they allow that or not. Doesn't seem that way though.
As the 2019 Spyder's go I like the RT by far the best in the styling department, followed by the F3, with the Ryker in last, who knows maybe it will grow on me like the F3 did.
On the video this morning they were talking to a MMA guy and he mentioned that it had reverse. You might see it now. It was to be uploaded this morning
https://mobile.twitter.com/CanAmOnRo...twgr%5Eprofile
Just for you Bob..... BING!
