Amen!
Printable View
I hope BRP designs a tensioner for the 2015 RT, for the top of the belt. I have a tensioner on the bottom of the belt and still have vibration. It keeps Meg and I from taking long distance trips as the vibration is very annoying.
Tried tightening or loosening the belt, that only moves the speed at which the vibration occurs. Valcourt is coming up next year and really want to resolve this issue before the trip.
There has got to be some combo of tensioner pressure & belt tension that works. I just rode 800 miles to Wing Ding in Billings up 90 mph at times. No vibration at all! Belt tension is about 200 & tensioner is set on 2nd or 3rd mark, I think.
Sent from my SM-T350 using Tapatalk
ordered!!!
next summer we can try them hahaa
http://www.spyderlovers.com/forums/s....php?p=1176287
Sent on Note 5 in Taptalk
Rode my 2016 F3T 320 miles round trip yesterday for first oil change and çheckup. Mechanic said the belt was loose at 800 newton's and he tightened to 750, which was supposedly spec. First time I have seen these numbers.
Any thoughts?
Vibration just moved to 65 and 70mph.
Looks as though I'll be getting the BRP tensioner.
I ordered mine a couple days ago. The dealer has in stock the aftermarket tensioner for way over $200, but I opted for the BRP unit at $34.95. If nothing else, this is a relatively easy part to fabricate if you have reliable resources. But, we will see how it all works out. My vibrations are so varied, anywhere from about 65 mph to 75 mph, but quite dependent on throttle position, i.e., and the resulting belt tension.
We will see how it all works out. Hopefully, the tensioner will eliminate the severity of the vibration if not completely clear up the problem.
Once again the dealer cannot be bothered to read the information sent to him from BRP. That is the spec for an RT, NOT and F3.
Spec for an F3 is 300N +- 100. You have WAY to much tension in that belt. Suggest you take it back and ask that it be corrected to the BRP spec.
The Spyder has hade a Belt vibration since I did my first test ride in 2007 we commented about it and was told that it was because the belt is so long, By time I got my Spyder in 2012 it still hade the same Vibration and was never addressed by the factory. Smothspyder came up with a belt tensioner It cost me over $250 and I did the install this should have been corrected by the factory from the very beginning as its a engineering issue the belt needs the carrier pulley with the additional tension. The vibration might not be a Safety issue but it can and will lead to engine problems. nojoke just saying.....jtpollock
OH by the way I have over 60,000 miles with the smothspyder tensioner with no complaints :2thumbs:
I agree--lowering the belt tension on the ground to 170# & maintain belt tracking was not easy on my easy model F3's. I had to remove the shaft nut side & file down the housing a touch to allow the tracking nut side to go far enough to the rear to be able to lower the other bolt side tension to 170# without affecting belt tracking. I have needed to place a cotter pin on all locking nut wheel shaft's in the past on several bikes for race track requirements. While this rear tire shaft is thicker, the metal is much softer. Drilling through the outer threads to permit a cotter pin was a a breeze compared to other bikes. That shaft metal is thicker but the metal is considerably softer. I had to tighten from the end of the shaft to the locking nut is approx 5/16", cotter pin is approx 3/16". For some reason I needed to tighten the shaft nut with the torque wrench on the screw end of the nut shaft. Tightening the shaft from the locking nut end would skew the tracking--every time.. Something is not straight on my drive frame, but lowering that 200#+ krikit tension to lower# is best. I torque closer to 150# or less, motorcycle rear wheels are closer to 80-90# torque. 160# rear wheel shaft torque seems unrealistic to me.
What is the procedure for ordering the new BRP tension roller from BRP--contact etc, I have the PN:
Thanks,
Darrell
Wait, isn't 750n lower than 800n? Someone is mistaken.
I ordered mine Yesterday and my Dealer told me they would install in for free...very nice...
Hey guys you should be bitching your asse's off and demanding that BRP fix our broken machines!
This is a major let-Down from Can Am, and I can't believe some of the reply's where guys are almost happy to pay for the parts and labor and loss time to put it on.
Can Am designs something that is broken - then as if its not enough we have to suffer with the vibration. After almost everyone is complaining, they come up with a Mickey Mouse hang on bandage "Fix" but wait . . . . . we end up paying for Can-Am's mistake.
I mean you don't have to be a Genius to realize when a belt gets "So" long you have to add an Idler somewhere. So instead of issuing a re-call to fix a know vibration problem - they come up with a fix and let the buyers foot the bill for their lack of engineering - and we have to:
1) Pay for a part that is already supposed to be on he bike.
2) Pay labor cost to install something that should already be included.
3) Put ourselves thought the BS of leaving a bike or waiting for it.
4) Suffer from the down time (transportation) to bring it to a dealer which for most of us is 1-2 days of obligation.
Guys - "Wake Up" there is nothing to be happy about!
The real questions is with all the hype of high technology and thousands of miles of research and all the "Expert" drivers - did no one at BRP even drive the damn bikes and feel such an obvious vibration problem. On my first test ride it took me 5 minutes to note the problem. When I mentioned it to the dealer he said when you feel the vibration - just slow down or speed up till it goes away! Hellooo . . . . .
Come On BRP Make This Right - fix our machines we already spent $25K
Nothing is broken, and this issue doesn't affect all of the bikes to the same degree...
And YELLING about it, is a pretty strong turn-off; unless you don't mind not being taken seriously... nojoke
Or did you just hit the "Big Font Button" in error? :D
IdleUp;
As I understand it, 5 minutes into your test ride you detected a vibration and mentioned it to the dealer. He suggested how to avoid feeling the vibration, but evidently, you chose to ignore his suggestion. Evidently, you went ahead and purchased the machine with the knowledge of the vibration. I fail to see how you can blame BRP for your decision. JMO
