Removing drain plugs and not over tightening when installing #101
Trying to figure out why so many here are stripping out (threads) plugs.
1. Turning the wrong direction when removing? Righty tighty- Lefty Loosey! (facing the plug--remember the plug is upside down)
2. Cross/threading when installing?
3. Over torquing when installing (I have never used a torque wrench to install) moderately tight and check for oil leaks after running) Torquing steel to an aluminum pan is a DS idea.
In my thirty years on the farm, working as a mechanic and aviation Mech (Technician for you young kids out there) and owning several hundred vehicles and toys in my lifetime I have never "stripped a plug" for the above reasons or any other reasons. ( I have made up several new swear words and thrown wrenches but never stripped a plug) IMO most are turning the plug the wrong direction (tightening to remove) and stripping the threads. More than a new plug here is needed to repair. Several different ways to do this.
Please for your next oil change lay on your back next to the ole spyder look up and decide right there if it is "lefty loosey" before you try that oversized wrench on the drain plug. Laying on your back, hand in the air, turn your fingers counter clock wise. That is how the plug is loosened.
On any plug always use a new crushed washer or O ring and one that is specified. Never reuse the
washer or O ring that you removed regardless of how good it looks.
One mentionable here is the factory installs these plugs dry (no oil) at the factory. Oil is added after install. The above is even more important in the first oil change as it will be seated dry and may be more difficult to remove and thus damage the threads. Subsequent changes will be easier because you ARE NOT GOING TO OVER TIGHTEN ARE YOU? Small wrench and never more than moderate hand tightening.
Jack
