Originally Posted by
Lamonster
I just did an oil change with the new setup and it took 10 minutes to pull the panel and drain all the oil and remove both filters. This is WAY faster than the old way. Thumbs up to BRP for this mod. :thumbup:
All you do now is loosen the two bolts in front of the foot peg (do not remove), then remove the air wing, remove the two push pins that hold the panel on and slide the whole thing out. Perhaps you can explain the frustration of taking a spyder in for service .(oil and filter) and, being told by the dealers that spyder says one hour (manuf. est.before the new panel) (and they charged me 30 bucks for that i said it's supposed to be free too bad ) last grand total 195.00 dollars. So far 300.00 for first service,second sevice 190.00, and most recent service was 195.00 at 10,000 miles on a 2012 rts se5 i have already told the dealer it is out of warranty in 2014 and so is my dealings with you .i would never do business with him again, i am really starting to miss the honda goldwing more and more i tried writing brp and guess what? no reply...if anyone on here's looking to get a spyder stay away from the belleville motorcycle mall in nj. If the new panel was supposed to make service fast and cheaper. It half worked, it is faster. but the dealer didnt pass on the savings ,oh no it said brp says one hour thats what i charge .if brp told the dealers 20 mins they would flip out or if they sent out flat rate oil change rates to the customers like car dealers and gmac does wow no bs now. i purchased an oil change kit on ebay filters gaskets o rings and copper washers 25 bucks and they made money. no dealer discount for my purchase. it must cost the dealer less these oil changes should be at 100 dollars its 10 minutes work??? brp needs to tell dealers stop charging 1 hr rates for a 10 or 20 minute job!!!!
