I would like this look on my 2014 RT-S
I would prefer this to the funky clear wind deflectors, even though I dont need it on my '14.
Can you say FARKLE??
: 2013 RT Elevated Temperature in Engine Compartment - Safety Campaign
what is going to keep the heat from getting my right foot,leg and thigh area? will the values of the Spyders return to what they should be?
I think they need some type of block off for the rt. side and a vent on the bottom of the Spyder, I understand that the market has the 2013 depreciated much lower than they should be because of the problems, the dealers will not make a good deal if you are trading a 2013 RT in for a newer model.
Can you give some examples or will it be on a case by case basis?
Quote:
Originally Posted by
BRPcare
Hi daviszoo1,
Yes. Please keep all receipts related to any work performed on your Spyder RT done with the intent of addressing high levels of heat in the engine compartment. When you visit your dealer to have the recall work performed, your dealer will notify us and be made aware of the procedure to follow, if any, to have this addressed. Note that only modifications performed with the specific intent of addressing high levels of heat in the engine compartment will be considered for compensation.
Examples:
Wrapping pipes
cat-bypass
heat coating
virtika scoops
additional heat shielding
Does this include labor?
Can you share elevated temp reduction data?
Thanks Steve, I spoke to my dealer service department today. They said they would order the parts for the fix. Can you please share data on how much temperature decrease BRP realized with these fixes, at low a d high speed and at what ambient temperatures the fixes were tested at please?
BRPcare
Hi jetmech,
Yes, as mentioned earlier the required parts are already available and will be shipping to dealers upon request.
