Vibration between 70 and 80 MPH
Quote:
Originally Posted by
Schnauzer
ours was vibrating at 80 mph up.. just turned 4000 on 2015 RT
.. Had it down to install trailer hitch. I left the rear wheel off the ground and set belt to 3/4 twist. sat it on the ground and it was closer to 5/8 twist. Took it out and ran it up to 90 mph.. no vibration at any time.. under load or even under power in to high a gear.. I checked the belt travel is about 1 1/4 at mid point.. It is definately a lot looser than when it came from the dealer.. We have not had it 2up yet.. but will and if any noticable difference, I will report..A comment like it is what it is, is not an answer..
Hi,
sounds like you changed the wave length of the belt. And in doing so might have canceled out the initial vibration. Like you added an extra wave. Something like the DOLBY noise canceling headphones. You might have found the answer that folks have been putting up with for years.:pray: The boys back at CAN AM might be interested in your findings. I know I am. Good Luck,
Ron
