But killing power may give you back control of the steering allowing you to correct back into your lane instead of braking into oncoming traffic. I don't know this for sure as the issue never happened on my Spyder, I'm just speculating.
Printable View
Here is an example, if you haven't already seen it:
http://www.spyderlovers.com/forums/s...ht=kill+switch
Check post #41 and on (baja ron and hdx's posts):
http://www.spyderlovers.com/forums/s...+switch&page=2
It's not in my nature to agree with people more than once or twice a week ,But :agree:I had my original Dps take me on white knuckle flights quite a few times [Across lanes twice] What saved me was hard breaking and hard steering back into my lane, and then loosen my grip on the bars when the DPS went [snapped] back to ''normal''; Hitting the kill switch would have left me with NO power to accelerate back into my lane, And would have slowed me down to a stop on the highway.:yikes:
As you can see by the various comments, there are many ways to skin a cat. The trouble comes with the delay that is needed to think up a solution, and evaluate one uncommon situation from a list of many possibilities. The kill switch is a simple, immediate solution to a variety of problems. That is one of its main reasons for being. If you get used to using it every time you shut off your Spyder, you will never hesitate when the need arises under pressure. To each his/her own, but I use the kill switches on all my vehicles that are equippped with them. I always know where my right thumb is, and where to find the switch.
One added bonus, when you are used to using the switch to turn the Spyder off, it becomes the first thing you look at if you hit it accidentally and kill the beast. :D
They don't always stall----- :-)
http://www.radiousa.com/blogs/post/j...sh-and-spun-a/
Well, I've been riding for more years than most of you. The order of stopping a two wheel bike is lower your feet to balance the bike as you come to a stop, then use the kill switch with your thumb to stop the engine without taking your hands off the handlebars, then you lean the bike over on its kick stand, then you turn off the main ignition switch and remove the key. And then you turn to fuel switch to OFF. It has worked for me and my Harleys for many many years. On the Spyder it is about the same proceedure except there's no fuel valve to shut off nor do you have to balance the Spyder when it's stopped. And no kick stand. But there is that difficult to find parking brake pedal that has to be pushed on all SE5s before your Spyder rolls away.
Stupid question time... :opps:
If you kill power by whatever your method of choice; you have shut off all of that wonderful computing skill that Nanny possesses... Wouldn't it be better to have her on your side when your World is turning into nothing but "big eyes and brown shorts"? :yikes:
