Originally Posted by
SithLord
Hello, new to the forum so please my apologies if I'm posting in the incorrect section.
I have an issue, but to explain and hopefully give as much information as possible I'll give a little history on my bike:
2015 RT-S SE6
7200 miles when purchased
Owned for two days as of this posting
Dealer purchased, used, no warranty
Stock, minus the shorty antenna
I got a ride from the Sacramento area, to San Diego to purchase this vehicle. I've heard the Spyders' fuel economy can be better, 30-40 MPG. Taking that information into account I decided to purchase one anyone. The dealer kept trying to push purchasing a warranty. When I refused, they kept having to take it to the back for various reasons: 1st being they needed to get the engine number. Shouldn't they have had that already? 2nd was to put air in tires. This one took about 20mins, with the excuse being their gauges were defective so they had to try 3 different inflators. Hmmm....
So I start on the 500 or so mile ride back home after filling the gas tank with 91 octane at the nearby Chevron. I noticed after about 2 hours, I had to fill up. I thought that was odd with a 6.9 gallon tank. So I decided to set my trip meter to give me some MPG readings. Being new to the machine, the trip meter was set to "pause" so at 2nd fill up my recording was incorrect. I fixed the issue, and successfully logged the mileage from 2nd fill up to now my 3rd fill up. 156 miles before the low fuel light came on. 20MPG!!!!
I know there are a ton of factors involved:
Speed - I was cruising, literally in cruise control at 80mph
Terrain - I5 North, relatively smooth with the now and then rough spots. A few hills.
Throttle control - Again, I set the cruise so after highway speed was reached, my hand wasn't engaging the throttle
Traffic - 85% of the trip I was in cruise control
Tire pressure - "Checked" at dealership
Air flow - Dealer's records indicate the air filter was changed as part of the inspection. No record of stock or K&N.
Spark plugs - 7k miles, should be a non factor
Load on machine/weight - minus my rain gear I packed in the trunk, I was solo (260lbs) with a hydration bladder on my back
Wind - there were parts of the trip that were windy, and I had my stock windscreen at full height (I'm 6'2)
I had to fill up a 4th time, FYI:
When I got home, I knew something was wrong. Being tired from the trip, I waited until the morning to check tire pressure. My gauge said the front two were low about 3 psi. I do NOT think this can account for losing about 10mpg.
I have not checked the air filter yet. Again, 5 year old bike with 7k miles. Unless the air filter is dipped in mud, I do not think that would account for 10mpg loss. My next thing is to use some Sea Foam injector cleaner. Long shot but I'll try it as previous owner may have used crap gas. I have not noticed any fuel leaks, smells or anything obvious. I use either Shell or Chevron in all my vehicles. For motorcycles and V6 and above I use premium, whatever that is depending on state (91, 92, 93 octane).
I've read the vacuum hoses sometimes fail. I've also read the ECU needs updating from time to time. I have an appointment with a dealer this week to have the bike checked out. Any suggestions? If I can only go about 150 miles between fill ups, with a naked bike, I'm not sure I can continue. I got this bike to two up on long cross state trips. Looking at other posts, I know this performance is not normal. Looking for suggestions as to what this can be.
