Hi,
May I ask where you are purchasing the bumpskid? I look at the vendors on the site and unless I missed it, do not see anyone who sells them. Thanks Ron
Printable View
What about aquaplaning?? I am afraid this big flat plastic piece will act as a surf board on any puddle!
I'd love to have a metal plate under the engine.
Did anyone in Spyderfest take a picture of the OEM plates that Spyderpop removed before installing the Bumpskid Plate? Some of them made me wonder how the :spyder2: still had a front end!:yikes:
Yes I have one and it save my Spyder's front end. :thumbup: You will love the plate
got my bumpskid delivered today. spyderpops.com surely is on top of his game. Great service on this order.
I wasn't sure if it was needed but bought one and when I installed it and when I saw the condition of the factory skidplate realized that it was a very good and wise investment.
It was the first mod I put on the bike.
I have used it, it works, and I would do it all over again,... and it looks great to boot!
The thing is, the skid can be replaced if it gets damaged too badly, the nose of your bike is a little different.
I don't know that the Bump Skid is necessary if you mean you can't live without it. But I can say for sure that you're much better off with it installed. It's more than just a piece of plastic. It is well thought out, looks good and is very functional.
It is the 1st piece of your Spyder to hit an obstruction (be it something at speed on the freeway or a wheel stop in a parking lot). Without the Bump Skid installed, a nicely painted, expensive part of your Spyder will take the hit.
The Bump Skid is well worth the money. Highly recommended! :thumbup:
I hit one of those highway alligators with mine. I'm sure I would have had a lot of damage without it. It helped my rt slide over the tire chunk and keep control.
Works better than auto correct:banghead:
I had one put on spyder fest last year, well on the way home foggy rainy didn't see a dead armadillo when thump crunch we ran it over , bump skid paid for itself in 5 miles after spyder fest 2012. Saved the frunk ! It's worth every penny! :2thumbs:
Gary
Well i think you get the picture here................ Get a Bumpskid. :thumbup:
Cruzr Joe
I've put most every mod I could and I've been resistant on the bumpskid because with the Elkas and shock relo kit I'm sitting pretty high. This is the first post I've seen espousing aerodynamic benefits. I noticed you put the sway bar on at same time. Do you think that had more to do with handling improvements?? I've got everything else you have including sway bar and sport windscreen. You definitely have me reconsidering this, thx
Short of this.... You should be fine. :thumbup:
http://seandavey.com/wp-content/uplo.../Raimana_1.jpg
I just completed the install of the bumpskid on my new RT LTD. Great piece of work by Spyderpops.com ... The screws sent for the installation work fine for the front, but were too short for the rear installation, as you need some grip to be able to mold it a little. I went and bought 4 each #6 metric screws, somewhat longer than was included by Spyderpops. Other than the screws, it was to my liking; I think it will do the job! To avoid damaging the edge of the skid, it seems like a hardened rubber rim would be an additional thing that should be designed into the bumpskid.
Nothing was cheap at SpyderFest. :P But had to get the BumpSkid from Pops. I was a wus and trailered my bike up/back from TX.
I had it strapped down on the open trailer. On the way back, I noticed in the mirror that the front straps were 'slack'! I pulled over and sure enough, the rear strap had broken and the bike had moved forward, going into the front rail/wall. Needless to say, there's a small ding/notch in the BS now BUT no crack or damage to the front plastic or frunk!
Was obviously worth the $. Have been busy since being back so haven't ridden enough to warrant comment on performance of it, but it surely can't hurt! :)
J / Roof Man
Having towed more bikes than I can count, over more miles than I can count, I can only say one thing...
"Double up on the tie-down straps...always!"
Straps break, move, or can snap in a collision. Two sets of straps is much cheaper than repairing your ride. I learned that the hard way, a long time ago.
I installed the Bumpskid today, I was surprised how much the bottom was scapped in only 800 miles. It was an easy installation.
I did remove the ribs along the edges so the plate fits better.
it looks good and I think it will improve fuel mileage. On just a short test after installation it feel solid in the front.
Is it necessary to lift the front end to install the bumpskid?
