Arr, you have seen my trailer. What I do is push it in sideways next to the wall, and park the Spyder in front of it (the side). While not a garage my parking space is about as long as a garage.
Printable View
Four bikes in the 2 car garage and the trailer in the 1 car. Car stays outside.
In our single car garage we have most everything that is not on a shelf stacked on dollies. So basically everything that is on the ground is also on wheels. We are constantly emptying out the garage to get to something that is on the far wall. :banghead: Our neighbors must think we are nuts.
I was gonna try something like a folding bed into the wall idea. The problem is the rear of the trailer. I had thought about having a flat piece of plywood that I would have "wheel stops". The plywood would have hinges to another piece of plywood secured to the floor. I envisioned securing the front part to the plywood, and having some pulley system to pull the front end up and towards the wall.
The other idea was the harness with a lift. I'm not sure my joists would support.
Bottom line is that my FX-35 is sitting out in the driveway and the spyder and trailer are in it's spot.
Chris
neat idea. You have some plywood, hinged onto a storage cabinet on the wall. back the trailer onto the plywood. secure the trailer to it with wheel straps and something to secure the tongue. then lift it up. could even use a crank setup (like a drawbridge) to raise it up into the "cabinet" with minimal effort. Huh. this may even be low tech enough that I can build it.
I got the idea from Mercedes, they use a cart to store their hardtops. http://www.silverstaroutfitters.com/...dtopcart_1.jpg
I bet Lamont has an idea. He never disconnects. At least, I've never seen a picture of his bike stand alone.
If I had a trailer I'd fabricate a trailer tip up rack sorta like the this one that I hacked out in a couple of minutes in SolidWorks. The proportions are not correct as I don't have a trailer to measure but you get the idea. Park the trailer on the rack, lock the ball, strap the tires down and stand it up next to the wall... if someone could provide the basic measurements of one I could make a scale model.
Yes, I have a fabrication and machine shop...
Enjoy
John
That's basically what I was "trying" to describe although I did not articulate it all that well. I talked about plywood, but metal would be even better. The key though is having something that will stop the tires at a sufficient distance that the rear end of the spyder will not hit what will ultimately be the base of your set up. There would need to be a good 2' (I'm guesstimating). The other thing would be that the portion that ultimately becomes the base will need to rotate. At least I think it would.
Chris
Hooking the trailer hitch to the ball on top would set the location of the trailer on the stand. I think that you could just pick it up and let it sit on the vertical part of the trailer holder, much like you stand anything up. Strapping the axle down would prevent any movement while vertical so the trailer and the trailer holder would be as one. That photo is just a simple depiction of my idea, it would need braces where the tubing changed direction. The rear of the trailer would be in front of the rear of the stand so there is no way you can touch the rear of the trailer as you raise the stand up.
John
That's basically the idea with the "moving cart" - just add casters on the base and you have the ultimate trailer dolly.
- Dry Weight 250 lbs
- Gross Trailer Weight Rating(GVWR) 400 lbs
- Maxium weight on trailer tongue 40 lbs
- Maximum loading capacity 150 lbs
- Overall Length 92.5"
- Overall Width 44.5"
- Overall Heigth 34.6"
- Ground Clearance 6.3"
- Wheel Size 12 x 4 inch
- Tire Pressure 35 psi
this is off the brp site about the trailer would need the ball to center of wheel measurement
an idea is round the pivit spot to mak the lifting of the front easer and when it stands full the weight would keep it slightly tipped back against the wall without touching
the ball attachment in the diagram would defiantly need gusseting and have some means of attaching the wheels to the bottom to keep it firmly on the rack
It would be close for an 8' ceiling but I think it could be made 7'9" tall and still work. The only number missing is the distance from the ball to the center of the wheels.
I think 1" x 14 gauge square tubing would be plenty heavy to hold the trailer. The model is without any bracing, but for sure some would be needed. Some eyes inline with the tires and short ratchet straps to fasten the tire to the rack would lock the trailer down.
It would be a balance between ease of lifting and stability with the radius on the corner. The bigger the radius the easier to lift and the less stable.
John
Another idea this is what I am installing in myhttp://www.aclifts.com/motorcycle/im...t-brochure.jpg new shop. I have an Aluma trailer I use behind the rt.
I like this! Must co$t a bunch. Checked the website. $2395. Half the cost of a new 622.
Think I define it as a place for the overflow of "stuff" once the basement is full. Although implied, usually never enough room to park 4-wheeled vehicles. A clean and well-organized one is usually the sign of a sick mind :)
Sorry - I know I was not the only one thinking it (no offense to those of you actually disciplined enough to have one well-organzied and park-able)
cover it real well or build a portable garage, or get one of those blow up things that they have for cars or get a cover for ur car, id leave the car out side, lol
