And thank you for that, it actually answers my question. I'll look there.
Printable View
No code involved seeing I didn't ask for application recommendation. And I wasn't really asking where to buy it, more of a brand recommendation because I've never seen the stuff before.
Funny, 2 other members were able to crack my "code" you just jumped to your conclusion.
You can get it on line, at some automotive parts stores and pretty much any place that sells electronics or computer gear.
Even Wal-Mart sells it!
I get a great deal on the small packets I include because I purchase several hundred at a time. So I am able to include this with my spark plug kits without adding much to the total cost.
If you get yours from one of these suggested locations you will most likely get much more than you need. So be very sparing with it. A very thin cote of Thermal Paste on all but the last 2 threads (at the electrode end, is all you need. It's not 'A Little Is Good so More Must Be Better' thing! :rolleyes:
Sorry to make such a big deal about such a simple thing. Just a lot of misunderstanding out there on this subject.
Good Luck!
http://www.spyderlovers.com/forums/i...quote_icon.png Originally Posted by Yazz http://www.spyderlovers.com/forums/i...post-right.png
When I first got my GS/RS, stock with the dual Two Bros, it had impressive back-fires on deceleration. I put the juice box in and the back-fires stopped.
It's up to you what you do, ride it for a while and decide if you want to put the juice box back in. My mechanic told me to let the engine breath, install a K&N filter.
The Juice Box is a O2 sensor that replaces the OEM O2 sensor on the rear of the exhaust pipes.
https://www.amazon.com/Two-Brothers-.../dp/B009L90V1E
:thumbup:Not a problem. I know I am a vendor but I try hard to educate and not push my stuff. Where anyone gets their gear is 100% their own business. If I can help someone get it right the 1st time that's the most important thing. Whether they get it from me or somewhere else.
And, in the interest of ...
:bdh:
... here is some more interesting information on the subject.
This first video is just for demonstration purposes. It is a Rotax promotional to get you to purchase an account. I'm not trying to push their service here. But the video does make a very good point in regards to this Thermal Paste or Heat Transfer issue.
Listen carefully to his last words. As his voice fades out he is saying that the thermal paste helps keep the spark plug within it's engineered heat range. Very important!
https://www.youtube.com/watch?v=9lntHJPbUdI
This 2nd video gives a pretty good demonstration of what you're actually trying to achieve with the Thermal Paste application. This guy is (I think) overly conservative. I would get the thermal paste within 2 threads of the electrode. The idea being NOT to get any ON the electrode.
https://www.youtube.com/watch?v=dgYcUuPZLrs
Not trying to beat anyone up with all of this. Just putting information out there so everyone can make an informed decision. No one knows it all. But together, with everyone pitching in what they do know. We can make life better for all of us!
Have a Great Day everyone!
I actually made my own plug wires and they work great. My local Autozone had a set of Accel 8mm plug wires on clearance that I picked up for $20. Got home and cut 2 wires the length of the stock ones and crimped the ends on. Works great. Seems to run better too. They look identical to BajaRons
Look into the wire you are using before going this route. Not to say it won't work. But most of the wire kits that you find are simply glorified OEM wires. They look just like my wire sets on the outside (because they may be). But they are very different where it counts (the part you can't see).
In other words. If the wire has a carbon core center conductor, they are really no better than the OEM wires in many respects. A better OEM version, perhaps. But you still have the primary issue. The problematic carbon core.
Carbon core wires are made with compressed graphite (like in your pencil). Fragile and typically 1,500 ohm's of power robbing resistance per foot. Add about 5,000 ohm's of resistance in the spark plug and that's a lot of power loss!
Compare this to the 50 ohm's of resistance per foot in helically wound, solid core wires that I use. A lot more voltage reaches the spark plug and the solid wire core does not break down. It's easier on your coils as well. Though coils are not a big failure item on the Spyder.
Helically wound wires are a lot more expensive to make and that's why manufacturers send their vehicles out with carbon core wires. Carbon core is cheap and will do the job for awhile. Still, I think my wire kits are competitively priced with the OEM sets from BRP.
BRP OEM wire sets will typically last between 15k & 25k. My wire sets will go at least 50k and many have gone much further.
Like many things. Spark plug wires seem simple. But in reality. The difference can be great and it's hidden where you can't see it.
There are a lot of great articles about this on the Internet. Here is one. If you want to skip the details and get to the crux of the matter. Scroll down to Spark Plug Wire Anatomy
and then scroll down to 'Finally, there’s the core.' just a few more lines down.
Happy Reading!
http://www.onallcylinders.com/2015/1...-your-vehicle/
There are solid core wires, and then there are solid core wires. This opens up a whole new aspect of ignition wires, but it is worth addressing.
In the olden days all ignition wires were pretty much like any other electrical wire. After all. You just needed to get an electrical charge from one place to another. The best way to do this was with a solid metal core (usually copper) surrounded by an insulator to keep it from shorting out. This worked really well until they started putting radios in cars. (AM, is very susceptible to electrical noise). So the engineers went looking for a solution.
Electromagnetic Interference (EMI) sometimes called Radio Frequency Interference (RFI) (which is simply EMI within the radio bandwidth) is naturally generated when a spark plug system is fired. You are essentially creating a very loud electromagnetic transmitter.
Later, car computers came along which can be even more susceptible to EMI than a radio, and the problem got worse. Manufacturers, looking for a good, cheap solution, settled on carbon core wires. Enough spark arrived at the spark plug to do the job, and the EMI issue was solved through very high electrical resistance.
Still, a solid metal core wire was much superior to the carbon core wire in every way except for the EMI issues. So, how to get back to the advantages of a solid, metal core wire without the EMI issues? This is where Spiral or Hectically Wound ignition wire comes in. By taking a very small solid copper alloy wire and winding it tightly around a special center material, then surrounding it with special shielding. All the advantages of a solid, metal core wire could be achieved and EMI could be reduced to levels even lower than produced by carbon core wires.
Though this wire is more expensive to make. It lasts at least twice as long, delivers much more electrical energy to the spark plug, and the EMI suppression is at least as good as a carbon core wire.
So, no worries with the right kind of 'Solid Core' wires. In fact. Some have gone to these solid core wires to resolve radio or computer issues.
I do not listen to the radio or use a CB on my Spyder. But I can tell you that I have a lot of customers using my wire who do. Maybe one of them will reply.
The manufacturers of the wire I use in my kits claims that EMI will be less than with OEM carbon core wires. If my wire kits were creating EMI issues there is no doubt I woudl have heard about it long ago. I've been selling these wire kits since 2008.
All good questions though. It's important to know as much about a product as you can to avoid getting something you won't be happy with.
Is this the vacuum hoses every one speaks of when it lags at a dead stop and wants to turn off?
BEtter pic
Well it wouldnt crank up and then i charged the battery all the way and it would work but went to limp mode. Changed the spark plugs to NGK iridiums then took off the 2 bros juice box and it ran better but would lag at a dead stop trying to go. Took the vacuum hoses off and they looked great. Checked the spark plug wires and there it was. See when I took off the spark plug wire on that difficult spot it was very hard to get the wire off. So might been damaged a little coming off. So since it’s arcing that might be my one and only problem. Lol
