If the oil is tested what would it reveal ..?
Quote:
Originally Posted by
BajaRon
Have your oil tested. The report may shock you. Especially on the 1330's.
Im curious so would it indicate we need to change our oil earlier or could we go even longer using a good synthetic..?
thanks
Will changing our own oil affect our warranty..?
I've always changed my oil on all of my vehicles but with this machine I don't want to do anything that would hurt me if I needed to make a warranty claim ..?
Thanks
ENGINE & TRANSMISSION LIFE VS. OIL CHANGES
classicvw
I'm sure they designed, built, and tested their engines thoroughly as every manufacturer does. If they were THAT FAR off- 9300 when it should have been 5000, not only would they be the most incompetent fools ever to build a vehicle, most everyone that has been sticking to the 9300 interval would have had an engine failure. That's just not happening.
I'll say it again- the guys that designed and built our engines know best. Why would they exaggerate how long you should go between oil changes and risk thousands of warranty claims or complaints?
I think, the bean counters at BRP asked the engineers what were the odds of the engine or transmission in the 1330 Ace package Failing BEFORE THE WARRANTY EXPIRED ..... if the " change oil & filter " intervals were extended ....... answer , maybe .02 %, but probably lower than that number. So BRP is not concerned about failures below 50,000 miles ...... after that it will the owners problem..... And this is not uncommon LOGIC in the AUTO industry. The manufactures cover their Butts yours not so much..... That's why I use Full Synthetic and change 5,000 mi. or less ....... Mike :thumbup:
