I put a new Comfort seat on the old girl, and I have to say so far the butt likes it!!!! I have to give a happy shout out to Bob on this site that sold it to me!!!!:cheers: Thank You !!!
Printable View
Actually it started last week but yesterday I finished replacing the OEM fog lights on my 2015 RT-S with a pair of LED bulbs. Here's is what I learned.
First, beware of seemingly innocent pauses during even the best "how to" videos. They can mask the tricky bits and make them appear easy. Second, replacing the right side bulb is not difficult, however, replacing the left side is downright impossible if your hands are anything larger than extra-small. The designer who located the cold air intake in close proximity to the left side fog lamp weather-proof cap should receive the cruel and unusual design punishment award.
No matter what I tried I could not manage to install the left side bulb and then re-attach the weather-proof cap. There just isn't enough room to for anyone with normal sized hands. The result is that it looks like I tried to beat back a rogue cactus with the back of both hands. And here's a bear your soul confession- all I managed to do is snap off the locating tabs on the LED lamp! The saving grace is that I bought two sets (the other being for my bride's RTL.) So, after a day to calm down and convince myself I'm not a complete idiot, I decided the best approach was the complicated way - disassemble the front of the machine.
Which brings me to yesterday. I had a good part of the day to myself (wife being occupied with a tele-conference) so I ran the RT-S up on ramps and removed all the bits and pieces that need to be removed so the frunk could then be extracted from the machine. Another confession: I was very reluctant to tackle that. As it happens, the process actually wasn't as horrible as I expected - six bolts, six electrical connectors, some push pins, a couple of Torx screws, one hose clamp (cold air intake) and trunk opening cable. And even with the frunk sitting on a cushion of the floor it was still a fiddly process to install the weather proof cap on the left side.
Added benefits of removing the frunk included cleaning the radiators and correctly attaching the battery hold down bracket. Much to my surprise, as well, was that the reassembly process was reasonably easy. One worthwhile tip: "lubricate" the inside of the cold air duct with a little dishwashing foam to make the re-connecting process less irritating. The bottom line is that it's all back together and, what' s more, everything works.
When the new LED bulb arrives I won't have as many reservations attacking my wife's 2012 RTL. And I'll replace the horn while I'm at it, It's buried deep in the bowls of the machine unlike the you-can-actually-reach-it location on my 2015.
Oh yeah, here's proof it actually happened.
You have my condolences on trying the "ol left light bulb on an RT" - the last time I did it I weighed up the possibility that if it blows again i'll trade it in - maybe, and similar to you I did lose weight - but only the skin from my hands :)
I haven't had the testicular fortitude to remove the frunk, started down the road of doing it a few times and chickened out for fear I'd need to balance the RT on one shoulder, hold the frunk in one hand, the bolts in another and steer some stupidly designed reverse locating lug all at the same time - but your notes give me confidence.
Put the Wick-it Performance stage 1 flashed ECU back into 2017 Spyder RTL (10 day turn around with priority mail taking 4 days now instead of 2 Florida to Louisiana and back), then added a Wolo Bad Boy air horn.
Still to be added: 6 outlet accessory bus, dual usb port in empty space between switches, add the K&N air filter, add the La monster idler pulley, driver highway extended foot rests, LED head, fog and driving lights, magic mirror magnetic mounts and drink holders. Have all already. Will be busy every day for the next month or so.
Inastalled air scoop tunnel grilles, not as simple a job as one may think.
I needed a higher and wider windshield that utilizes the stock brackets and has a flip, so I called my go-to w/s maker, 7Jurock and they made one to my specs and only charges what a stock one would cost. It works great for me - all is calm in the rider's seat.
Sorry about the upside down pics. I wish I knew how to correct this.
Added two handlebar bar end cap weights - didn't need washers on right side - throttle works as before.
Took a short ride - Doesn't do much if anything but looks good.
Since that took all of 5 minutes - I decided to clean her up a bit - used old brand of Honda clean and polish spray almost everywhere.
ON a few of my past two wheelers I filled the handle bars (handlebars being long one piece) with buckshot and added heavy insert bar end weights - all but eliminated handlebar vibration.
Moving Spyder to storage unit today. Snow in forecast for the weekend. Hopefully we will get some decent weather after next weeks cold and wet so I can get in another ride or two. Storage unit is only 5 minuets from home.
End of season oil/filter change. However, the season doesn't really end until salt hits the roads.
Got my USA and US Army flags all set up. Some 16ga. galvanized steel painted and bent JUST SO mounted where the trunk lid closed. BRP so kindly provided 4 large screws there. I'm far to stingy to pay over $90 for less than $10 of material. The new USA flag cost more than both mounts.
Lew L
Loaded it up on the trailer today for a trip tomorrow from VA down to FL. Gotta go down and help my parents a bit with some medical concerns and not sure how long I may be there, so.........
I know its not the safest time to travel, however, I haven't seen them in over a year and you never know with age creeping up.
I will limit my contact with other people as much as possible. Taking a leisurely 3 day journey using the secondary roads instead of I95 and I75 - the latter being the worst of them.
2019 RT-S, season end oil and filter change.
Motul 300V, Outlaw filter, BajaRon O-Ring kit.
https://www.motul.com/ca/en-US/produ...d-racing-15w50
https://www.amazon.com/dp/B077ZRCCNC...?ie=UTF8&psc=1
NOCO tender plugged in, sleep well until April 1....
Road tested the saddle modifications plus heat and a wider and taller (18" 7Jurock) windshield. Wife was passenger and granddaughter rode her Honda Magna along the Columbia River to Stenson, WA for lunch.
The ride began in low 50* temp and the bun warmer did a great job of keeping us comfy. 20 years ago, I discovered seat heat on a rented BMW KLT and I never want to leave home without it now.
Thanks to its flip, the windshield did a great job of shielding us. I was in a calm and the wife said there was much less wind on her than with the normal width, 16" 7Jurock with a flip.
Gotta go out today too and take advantage of an all too rare (for this time of year) 64* high.
Today I renewed my license and Insurance for another 12 months. Went for a short scoot. Temperature in the high 40’s although when I got near the mountains it cooled off considerably. Supposed to be heavy rain now for the remainder of the week. I ride whenever it’s dry. The cooler temps don’t bother me as much as the wet does.....I can dress easily for the cold.
Installed the drivers backrest that the seller included in the deal.
I ordered a Pedal Commander to go with my Stage II tune..it should be interesting..
Changed out the grill filters on my 2020 RT and my wife's 2018 F3. Lots of bugs in the old filters from our 9000 mile trip. Very pleased that they didn't make it to our radiators!
Installed a double usb port on the dash, and took a 50 mile ride.
Fixed my right run/turn fender lights on my 2020 RT. Turn out to be a defective y spliter wire.
The pedal commander is fantastic...it works hand in hand with the stage II tune...worth every penny.
Sealed the cement on the new shop floor and the outside floor for the new Spyder shop built from the old milk barn. Now to get the wiring insulation and sheet rocking done hopefully before winter sets in to hard.
With spring like wx here in central N.C., rode 198 miles with a buddy. Mostly back roads in foot hills of the Blue Ridge.
I'm new here. Yesterday I purchased a rack for my 2021 Spyder F3-T
