Parking break failure!
I need to tow my 2012 RT LTD to the dealer. As you all know when the parking brake is engaged, the bike can't be moved. I am not sure if I ever saw a thread on how to move the spyder when the battery is dead or the parking brake fails. My battery was recently updated but now I have a parking light issue that won't disengaged.
Does anyone have any suggestions?
Your advice is appreciated.
Thanks
Check your brake/frunk release switch for proper contact/dirty connections....happened to me
Sure
Just disconnect the cable.
Can you hear the brake motor when trying to disengage? If yes remove side right panels to get to the parking brake pulley to see if the cable came off, also check the micro switch under the pulley to see if it's still working.
http://uploads.tapatalk-cdn.com/2016...b1f4fa966c.jpg
http://uploads.tapatalk-cdn.com/2016...9198cfb08d.jpg
Sent from my iPhone using Tapatalk Pro
