Going to replace the 2 vacuum hoses on my 2012 RTS SE5.
are the hoses 3mm or 4mm?
Jim
Printable View
Jim
3mm. Use silicon turbo wastegate tubing and you will never have to replace them again.
Just buy 3mm silicone hose and cut to length. Much cheaper, higher quality hose and readily available at your local Napa auto parts. You need less than 10 inches of hose to do both of them. Remove old hose, cut new one to same length and install.
had to do it to mind just two weeks ago......:(
I believe the NAPA hose part # is H466.
I changed the hoses on my 2011 rt, used the part from Napa worked fine, there is 6 feet of hose in the box, you might want to chk your crank case vent hose mine had cracking on it also. just a reminder the chrome tamper proof screws do not need to be removed they have push pin and grommets to hold the panel on,
