Anyone have any luck using the Kumho brand ties on the their spyders yet?:yikes:
Printable View
Folks have been running the Kumho tire on Spyders for years. You can read for days about the subject, just search on Kumho.
posted to your other request. GTO (gas tires and oil) are a often discussed subject here. Search it out for days of confusing reading with end result being....choice is yours try and report...:thumbup:
For the last time there is no Kendra Tires. Kendra is bubblehead reality star Kenda makes tires. :banghead:
Really happy now I'm running Kumho tires instead of the Kenda Krap!!
Already travelled more distance on the Kumho's than the distance that wore the Kendas to the canvas, & the Kumhos still look brand new!! Of course, they are a heavier tire so they don't need quite as much air pressure in them in order to carry the same load or they'll have less traction &/or hydroplane in the wet, so I'm running 16-17 psi up front & 26 psi in the rear. Ride & handling is phenomenal, they stick like **** to a blanket, & they are much smoother & quieter than the Kendas too - and the look like last double or more distance than the Kendas did!!
Just like fitting the BajaRon Swaybar, my only regret about the change is that I didn't swap to the Kumho's a lot sooner!! :thumbup:
