F3-S Rear running/brake/turn signal lights wiring code
Appreciate help with rear lights wiring colors.
There are same color coded wires running separately to Right and Left sides rear bulbs.
F-3S 3 wires for each side
Black - ground?
White - ignition switch +12V - running lights/brake with higher voltage??
Grey with maybe a red stripe - turn signal?????
I am installing lighting for my top case and its controller has five wires:
Blue - switched 12V
Red - brake light
Green - right turn signal
Yellow - left turn signal
Black - ground
If I am guessing correctly: Blue to Aux. power, Red to F3 white, Green to F3 Right grey/red, yellow to F3 left grey/red, and black to any black.
thanks in advance - yes I did search service manual couldn't find info - probably because of my pee brain and old age.
Japanese F3 LED tail lights
Oh - I also discovered that the Japanese version of the F3 has LED tail lights.
Come on isn't the United States the largest Spyder market in the world and we get stuck with my grandfather's incandescent bulbs. For crying out loud this is 2015 and a new 2015 Spyder model:gaah:
Top case LED lights work perfectly
Top case: Running, brake, turn signals, flashers LED lights all work perfectly . F3 is happy and I am pleased to have higher functioning tail lights.:D
Saddlebags with LED lights
I own a 2016 Can Am Sypder F3. My saddlebags have 2 wires for each LED light as follows; Red for positive and white for brake/running/signal lights. Can anyone tell me where I can connect those wires under the passenger seat, to which color? Thanks
