How do you know if your front tires are bad?
OK, I've only had my 2014 RT-S for about three months and 1400 miles, but I'm still concerned about the nervous front end (Yes, I had the alignment laser-checked, it's OK; yes, the tire pressure is at 20 psi.). The beast seems unsettled, like the front end is constantly hunting for a new direction every few microseconds. (Yes, I know about the potential for over-controlling the handlebars, but this happens even if I'm even using the gentle, open-palm control method recommended elsewhere on this forum.) This is in contrast to the video a few posts below by finless, "What it's like to ride a Spyder." I noticed at one point in the video, he had the confidence to take both hands off the handlebars, just for a moment. I don't dare do that.
At times, on a smooth, straight road, everything comes together and I think this is a keeper. Then a few minutes later, it's as twitchy as a meth addict after 3 double espressos. Needless to day, my machine is not a confidence-builder in the turns. Although I'm s-l-o-w-l-y learning to trust the nanny to keep me out of trouble, it still raises the pucker factor. All this keeps me wondering if I should keep the Spyder, or write it off as something just not for me.
I have noticed one thing: in right-hand turns, I can generally carve a smooth curve. In left-hand turns, I'm constantly making minor corrections; it doesn't seem to want to hold a curve. So I'm wondering if I have a bad tire or two. I've read on the forum that BRP had a run of some bad front tires a while back. If the consensus is bad tires, how do I convince a skeptical dealer?
I've also read that the 2014 RTs don't really need a sway bar as badly as earlier models. Is this true? I'm reluctant to make that investment, as I'm still undecided as to whether I'll keep the Spyder.
Thanks for any feedback here. This forum has been a real help learning about Spyders.
THE TIRES ARE THE PROBLEM
IMHO, before you spend all sorts of money on various fixes and or parts .............I think from what you have said and the History of KENDA tires in General, I wouldn't be at all surprised if your ties are the issue . Either bad belt/s or very bad balance or maybe both................This should be a WARRANTY issue .............Mike :thumbup:
Try this on 2-lane blacktop roads with depressions from heavy vehicles
My stock 2014 Limited Spyder drove like a snowmobile on 2-lane blacktop roads with significant depressions in each lane from the wheels of heavy vehicles.
Then, I discovered a major improvement in steering/handling by merely putting my front-left wheel near the center line. This automatically positions the front-right wheel on the crown/high spot between the depressions. Rear wheel travels in the leftmost depression.
Definitely an improvement. For the record, I inflate my front-tires at 20-PSI & rear at 28-PSI.
