Stock tires will not track straight
My 2014 RT limited was pulling to the right so I had it laser aligned but that did not solve the problem. I am using exactly 20 psi in both front tires. Mike Loescher (the inventor or the laser alignment system) suggested that I try switching the front tires. I did this and found that now the bike pulled to the left. Mike said that Can Am has had a problem with many of the stock tires on the 2014 RT Limited bikes. I replaced the tires back to their correct position and then informed my dealer (Tampa Bay Power Sports) about this problem. I am waiting to see if they are going to replace the tires. Has anyone else had similar problem?
New tires fixed the problem
Tampa Bay Power Sports replaced both front tires, now my Spyder tracks perfectly.
Pulling to the Right hard
2014 RT L Mine is pulling hard to the right also. Dealer has replaced three sets of tires so I am on the 4th set of tires. I have had a laser alignment done it did get rid of most of the shimmy in the front end but it still pulls to the right. let go of the handle bar and it pulls to the right 1/2" hard. the only way that it will go down the road straight is if you put the tires on backwards (*reverse rotation) it will go down the road for over a 1/10 mile with no hands at all! Is there any thing that will help but a new set of tires?
