2 Attachment(s)
Simple $40 X Phone Mount for RT with SE5
The RT handlebars are BIG.
Here's how I did a pretty nice mount. Might not work if you have a clutch -- I have an SE5 so I don't know.
Start with this:
http://www.amazon.com/gp/product/B004O8LF26
and these two as well:
http://www.amazon.com/gp/product/B005KWPJ04
http://www.amazon.com/gp/product/B0055PH0XA
Just about $40 -- $20 if you only want the ball and the arm and you don't want the X mount.
Then I used 4 19cm black zip ties. I had these on hand, but Big Lots (closeout kind of store) sold these to me awhile back for $2.50 for a bag of 100.
The mount is going to go right next to the left handlebar grip. Orient the ball on the handlebar and insert two zip ties in the "back" holes (closest to the windshield). Put the flat side of the zip head facing the driver and flush with the top of the mount. Now thread two more zip ties through the "front" holes with the zip heads under the mount. Insert the front ties into the back zip heads and tighten just a little bit. Now insert the back zip ties into the front zip heads and tighten so that the heads are near the bottom of the handlebar. Make sure the top stays flush. Tighten until they are pretty inconspicuous. If you mess up, the zip ties are cheap. Cut them and start again.
Now take some needlenose pliers and tighten the h*** out of the ties. If you get it tight enough it is going NOWHERE. Cut the ties flush with the head.
Then mount the arm and the X mount and the phone and you are done. Woo hoo! Seems to work although I haven't been out cruising at 70MPH yet with it. However, I did just take it out on the highway for a good 1/2 hour and it up to 60MPH. No sign of motion.
Of course, you could use the ball for anything you can use a ball for -- cup holder etc.
The finished product (phone not included)
Close up of the zip tie work.
I don't have any long enough, but they do make stainless zip ties if you are into the chrome look, that might work too.
DISCLAIMER: Not responsible for damage to your Spyder, your phone, your zip ties, or your thumbs. May cause hair loss and is known by the state of California to cause scurvy. Don't use your phone while in motion (no kidding on that one). Void where prohibited by law. No cash value. Statements not evaluated by the FDA, EPA, IRS, or CIA.
