Won't Run, check engine light won't clear
Alright, I've installed iridium plugs and new wires, BajaRon's, replaced the fuel filter, replaced the exhaust with the Can-Am by Hindle, wrapped the exhaust system with Titanium exhaust wrap. Battery is fully charged. Fuel is new with Sea foam additive. Air filter is a Green re-useable from ESI. Turn key and clear the initial star-up screen. The engine check light will not clear. Press the engine start button, limp mode scrolls across the screen, only the rear cylinder is firing, I know this because the exhaust pipe is warm. Front pipe is cold. Engine runs for about 5 seconds then shuts down. I have rechecked every electrical plug in the engine compartment, to verify they are connected. I'm at a loss. I do not know how to check for fault codes. I know it may seem odd, but have never had a problem with my 2008 RS, I have 19,000 miles on her and now, This! I threw the old plugs and wires away. I hope you techs can suggest what my next step should be. I'd also like to know how to check codes, as well.:banghead::mad::banghead::yikes: Thanks for any help:bowdown::coffee::coffee:
Brainstorming.... Don't flame me. Ignition coil, spark plugs, or wires. The spark plug test will tell a lot. Ron's plugs are gapped already...or at least mine were.
Waving the flag of Victory
Well, as I said in my last post, I thought I had to surrender. Had Venom delivered to the shop, they told me it would be at least a week before they could get to her.:mad: Then by the time I got home there was a message on my phone, saying that the manager had told them to just plug it into "BUDS", The ECM had to be reset and she is purrrrrrrrring. Come and get her, total cost, $89.00, for the diagnostics. :yes::yes::yes::yes::yes::yes: Once again I want to thank everyone who made suggestion, and took the time to look at my post. Sincerely a very happy man. 1Venom (Rod) ALLOUT Cycles in Chesapeake, VA, rocks!!!!!!!!!!!!!!!!!!!:bowdown::bowdown::bowdown ::clap::clap::clap:
