Originally Posted by
BajaRon
As you can see, you're going to get a lot of opinions. I can tell you that the 2010 RT had the weakest shocks and sway bar of them all. So you will actually see a greater improvement that those with later model RT's.
Personally, I would get both the sway bar and shocks. You will be amazed.
The OEM 2012 shocks are not Elka's but they are much improved over the earlier versions. Better dampening and I believe a stiffer spring.
And the sway bar will probably knock your socks off. These 2 upgrades will complement each other and fix a lot of what was wrong with the suspension on the 2010 RT's.
If you do both, let us know what you think when you're done. For the money, I think you'll be very pleased.
