I have a question about using ride on . are the bottles marked so you know that you have the correct amount in the tire? I know it is 13oz in the front & 18oz in the rear tire. thank you.
Printable View
They are marked; but, sometimes you don't get a full bottle.
They are marked and pretty easy to eye-ball it.... but I put the bottle on a scale and weigh it... then just keep re-weighing it until you've put the right amount in.....
Great question, as I am planning to add Ride-on to my tires. Not to highjack the thread, but I have read where you can remove the weights on the tires. My question is can you leave them on?
I left the weights on, rides great with the Ride-on in.
I have left mine on also. If you are thinking about removing them, mark where they are at; so, if you decide you need them, you know where they go.
Also, if you warm the Ride-On it goes in much easier. I just set my bottles in a bucket of hot water for a few minutes.
Do you guys think this is really a worthwhile upgrade?
How much is peace of mind worth?
How many bottles should I purchase for a gs?
The auto formula comes in 16 oz. containers. How much are you putting in the fronts and the rear? Not everybody puts in the same. But, 3 bottles should do it.
Check out post #92 here:
http://www.spyderlovers.com/forums/s...143#post443143
while reading this post , the ride on stuff sounds good so is there a post on here so i can read exactly what it is and does and if its only in the usa cheers
Go here:
http://www.ride-onshop.com/content.cgi
If you go to the post I linked above and go to post #1 you can see about a 10% discount.
