Originally Posted by
frank3
I had the same experience about a week ago. Went to basement garage, hand pushed RT out to pad and closed garage door (all to keep from distribing wife's sleep) and tried to start the RT. Turned over but would never fire. Gave up and took my truck to work. Later in the day, I returned home and tried the RT again. Same result, turned over but no fire. Plenty of gas. Put Rt on a battery charger and tried several more times with no result. Called my dealer and they sent a trailer to pickup the RT. While waiting, I tried it again and finally, it started but sounded and smelled like it had been flooded. Wasn't able to determine cause of starting failure so let the dealer take it to check it out. They put it on BUDS and got no codes. They wern't able to get it to fail again. BTW, I had never touched the throttle during any of the starting attempts. Anyway, got it back home the next day and have reidden it every day during the last week with no more starting problems. Still don't know what might have caused the problem but I thought it might have had something to do with removing it from a air conditioned garage into the much warmer outside air prior to starting. Computer might have called for richer fuel mixture than was actually required in warmer outside air. Hope it dosn't happen again while I'm away from home on a long trip.
