This past Saturday, I spent the day doing a front end alignment on my Spyder. I decided to do my own, rather than taking it to the shop. The reason being, I have paid for two front end alignments over the past nine months, and both times, the shop said; evrything it within spec. Well when I did it, it was definately not within spec.
I have been having uneven tire wear on the right front tire, and the Spyder has been pulling to the left. So, it needs a front end alignnment. I followed the service manual for this. It is time consuming, takes a lot of patience, and you do a lot of mesauring. When I got started the left tire had a toe-in of over 1". The right tire had a Toe-out of over 2". Definately not straight.
The toe is determine, by the front measurement minus rear mesurement equals toe-out/in. The measurement is taken from a center point on the frame to a paralel point, even with the disc brake rotors. Both in front of the rotors and behind the rotors.
Example:
Front: 25.75
Rear: -24.75 (Measurements are from a center point.)
Equals: 1.0 toe-out
Once I got done both tires were striaght. Then I had to take the Spyder to the shop, to have the DPS reset to Zero, along with the Steering Angle Sensor.
I am happy I did this. The Spyder handles much smoother, with a lot less effort.
I will keep you posted if this cleared up the uneven tire wear issues I was having. I sure hope so.
