1 Attachment(s)
2018 RT engine block with hole - is it repairable?
I just purchased what I was told is a repairable Spyder but it is questionable. After cutting away a large portion of the front end of the damage I noticed there was an oil leak. It turns out that the front link rod that is attached to the engine was pushed so hard that it caused a one inch diameter hole in the engine just above the starter. I appears as though it is made of cast aluminum and I have the broken off part. Is this repairable in a shop? If not it looks like I will have to strip the engine to its good parts and sell them off. THANKS IN ADVANCE FOR THE INPUT.
