Anyone else found an RT without the wire for lower front Auxiliary light?
Between myself and numerous friends, we have all bought and installed the lower front auxiliary light on 2020 through 2023 RT's. Today I went to install one on another friends' 2022 RTL and found that there is no wire harness attached to the blanking plate installed in that location. I tried to look around and fish around through the hole to see if the wire connector was laying loose but with no luck. This is one of those bikes that shipped from the factory without some parts, notably the rear heated grips and switch. Has anyone else found a RTL without this wire? I assume that I'll have to remove the frunk to try to find the wire IF it's there...
