2 Attachment(s)
Attn: Spyder & Ryker owners, my $5 front suspension hack. fantastic on uneven roads!
First a little history on my ride. I bought a 2015 Spyder RS SM5 this spring. It had 9500 miles on it. It had original Kenda tires and Fox shocks in front. As you may have guessed already, the steering tracking was terrible. Step 1: replace all tires...Kumho Ecsta 225/50R15 in rear, Farroad FRD16 165/65R15 in front (55 is original size ratio, so I gained 1/2 inch in ground clearance). These tires seem to have a soft sidewall...like the Kenda's, FYI. So, after playing with tire pressures, I settled on 28 PSIG for easier cornering (i.e. less push/pull input by me!). The lower pressures [that most users set to] didn't seem to mitigate front end jump on uneven or poorly maintained roads. It could just be the tires, IDK. Step 2: added a BajaRon anti-sway bar and endlinks. More improvement, but still not feeling safe on narrow Texas backroads with high-speed oncoming traffic. Step 3: Adjusted Fox shocks to maximum preload. Still better, but not good enough for my riding comfort. I'm thinking now that I may have to upgrade to aftermarket front shocks, but just not ready to make the investment at this time. This is where my "hack" idea comes in. With the preload maxed, the shock "dampening" was a better match. What I needed was about 2 inches of sag to get the shocks in a better position for up or down wheel travel. I needed some weight in front to increase the sag and test my theory. My test weights were limestone rocks...which grow out of the ground on my land every year. I just set up a cushion in the frunk and started adding the rocks until I got about 1-1/2" sag. I took it out for test rides until I was happy with the response. It came out to about 50 lbs. The result was amazing! I didn't really lose any undercarriage clearance. It's still 5-1/4", right where I started before maxing preload and adding taller tires. At this time... I removed the rocks, set up a cardboard form and trash bag in the frunk, and mixed a 60lb bag of ready mix concrete. I poured it right in there! final weight is 65 lbs. I added a couple handles to be able to remove it when required. After 24 hrs, I removed the weight... as the concrete releases moisture as it cures. Takes about 2 weeks for all the moisture to go away. Now I have a perfectly formed weight with a bottom layer of cardboard for cushioning. There you go...my $5 hack. If you're like me and can't afford aftermarket shocks, I encourage others to try adding weights in their frunks and report your results, too. See pics below of my concrete form. I hope this helps some ryders!
