The One Handed Newbie...Torch or WD?
Well as mentioned in my first post, received the Spyder F3 number 4 UFIT floorboards today. Attempted to remove the two number 7 hex screws holding on the oem floorboards. No joy, not even a small budge :( so now deciding if I heat the threaded portion of the bracket or WD it first to see if it's simply corrosion on the like new 2018 machine. Afraid if I WD with no success I'll have flames if I heat with a propane torch next :sour: The long hex wrench had zero movement and the 3/8 ratchet hex attachment started to round the hex-head. I have found working with one hand limiting to put it kindly. Anyone else have this issue and good success with a different solution? Regards,
