We are planning to get the driver backrest, passenger armrests, and the auxiliary light. Should we pay for installation at dealer or are they pretty easy to install?
Printable View
Pretty easy to install.
Having said that, it should be pretty easy for your dealer to install also, and shouldn't cost much extra.
Like everything on these things there's going to be some panel removal going on there, so if your cool with all of that it should be a easy thing! Good luck!
:hun:Ease or not they go by BRP rated time estimates:barf: at expensive shop rates:gaah::banghead: :sour: & DIY you get to know your bike better for the unexpected things that happen on the road:thumbup: just take your time , don’t get aggravated & brake something :lecturef_smilie:
Back rest was easy, except for the L shape bike support, but that was on me. The the front aux light is pretty much plug and play, arm rests, that a dealer shop job.
The backrest and auxiliary light are pretty easy to install. Even a Caveman can do it. I don't know about the passenger armrests.
*** Note*** Has your passenger sat on one with the passenger armrests? My understanding is that it could be a little difficult to get on and off with them. A few people on here have gotten them and then took them off because of that. It could be a costly mistake.
Including the accessories in the OTD price is a good idea to see how much the dealership will include to have a satisfied customer. It might also give you some leverage if there is more than one dealership within reasonable shopping distance. Create a spreadsheet and list everything to get a bottom line number and shop it hard.
It is indeed tight for the passenger to mount and dismount, why o why BRP did not have them fold up is beyond me. I had nothing to go by when I had the dealer install because the wife wanted them for our TN trip and mountain carving, so it is what it is. If I had it to do over, I might wait for an after market. But I did get an OEM set very reasonable from a rider that removed his for the very reason it was too tight for his passenger.
Install is a big deal unless you're one of those that enjoys that mechanical stuff and it's therapeutic, and is nimble. Installation of accessories takes a lot of patience and time. One little screw up is demoralizing.
The light is probably the easiest to install accessory that BRP sells! Took me all of 5 minutes. The backrest should be another easy install. The armrests? Sounds like some work. Let the dealer do the armrests. :thumbup: Tom :spyder:
Thanks to all your replies. I will definitely see (as best I can) if the armrests will be comfortable before installing.
My wife has always got on the drivers seat and slid back to her spot and has no prob on the 20. She really likes the uptick on the front of the arm rests and finds them very comfortable.
You can go to the owners section on the BRP web page and review the installation instructions to determine the ease or difficulty of the installation.
Hey Woods by golly, that's a good tip, I'll pass that along to the wife.
Thanks to all.
We got the auxiliary light installed. My husband even bought one of those torx ratchets to make sure it was tightened right, like it said in the instructions. Is there anything that needs to be hooked up, like a wire connection? The auxiliary light doesn't come on.
Yes there is a wire behind the plate. Plug it in, screw in the light and it should be all set
We snapped the light unit into the wired recepacle, then put the 4 screws into the holes to attach it to the bike. Are we missing something, or did we just get a bad light?
The 2020'S are a lot easier to work on than the earlier RT's. Lower light in front is a plug and play with four screw to install, no drilling. Arm rest could be a little tougher you have the two side panels to remove that is where the arm rest mounts.
Is it's BRP parts installed by a dealer tech that you should have warranty coverage on the parts also.
Good luck
SpyDerred15
