Exactly 1/2 of my screen is white, right side ok. Called garmin and they said $180 for repair, anyone have ANY ideas, PLEASE?:pray:
Printable View
See if you can buy a used one for less than $180.
I don't remember seeing anybody who does "repairs" except Garmin.
used ones $600
Time to bite the bullet!
That sucks, but $180 still less than any price I have seen for a used one. How long is the warranty with the rebuild?
You can buy a very good GPS for an automobile for a lot less than that, and it may not be waterproof but a pastic bag and rubberband will fix that. There are many mounts that will work with the Spyder, the choice is yours. The problem you describe points to either a power problem or the display, and you are probably stuck with the Garmin repain center.
That sucks! However, if you like your 590 (I like mine very much) then $180 is better than changing it out for something else. Remember, that harness for the 590 isn't cheap. If you check on YouTube for Garmin screen replacement there are many videos, but I couldn't find one that shows how to do it for the 590.
Have you accomplished any of the typical DIY possible fixes. Remove the battery if possible and hold the power switch on for a few seconds. Is there any means to do a master system reset. Sometimes Garmins have keystroke access to various systems. This is not explained in the owners manuals. They may gain access to certain functions Garmin did not intend owners to play with and being Garmin they share nothing it seems.
Yes You Tube videos may offer insight, but in the past I found GPS specific websites / forums with a huge amount of technical info, and the ability to ask for answers from GPS smart guys and girls.
Typical Garmin is they do not repair your unit and return it, most times they send out a previously refurbished unit. If you have any type of info, maps, open street maps, settings or memory installed, gather it up and out of your unit before sending it in for replacement.
Maybe some time here could offer insight.
http://forums.gpsreview.net/categories/gps-discussions
I'd guess that the screen/card has physically had it, & the only fix for that will be a dismantle, unsolder, replace with new screen/card, resolder, reassemble everything type job.... in which case $180 seems pretty cheap for what they likely hafta do!! :shocked:
But yeah strip off &/or back-up/save elsewhere everything you want to be able to re-access BEFORE you send it away for repairs.... you should only need to lose the whole lot once to learn that lesson! :gaah:
Have you tried doing a factory reset?
https://www.youtube.com/watch?v=W9sF-BR9XAY
Indeed.....different strokes........
When riding, I am watching the traffic and the scenery. I am NOT watching a GPS screen.
Without the audio prompts I consider a GPS virtually worthless......and somewhat of a safety hazzard.
The only time I do not want to be notified that I "missed a turn" is when I do that on purpose to take an alternate route and it seems to catch up fairly quickly.
If I am out just randomly riding with no destination in mind, I leave it shut off until it is time to find my way back home.
I've been pretty much lost around Atlanta a few times and the Garmin is invaluable when that happens.
Thanks all for trying to help. I did try factory reset. Guess I have no other choice other than paying. Oh well......
[QUOTE=Easy Rider;1412738]Indeed.....different strokes........
Agree :agree:
I have very good luck working with the Garmin factory repair department. Had a unit go on the frits. Called them up they talked me threw the reset steps then they decided it had to be repaired, sent it in they sent me another one to replace it. Worked fine ever since! Good company to work with!
Have you connected it to your pc via USB? I just had a tablet do a similar thing and I ran across a note online about connecting it to my computer before sending it in for repair. Worked like a champ and the tablet has been fine since. Don't understand why they would be offering better results than a factory reset but I'll take it.
CJ JAX
Did connect to computer. NG===sent off to Garmin for repair this morning, THANKS EVERYONE for trying to help!!:banghead::banghead:
