Good afternoon, I have music on my 660 and when I play a song it only plays one song and stops, why does it not keep playing songs? Thanks, MIKE
Printable View
Greetings. I had a Zumo on my two bike. I believe you have to create a playlist. Use some music software (iTunes, etc.) with the Zumo connected to your computer. Drag and drop your selected songs to the playlist. Then when you want to play, select the playlist. You can make multiple playlists (you have to name them) with different groups of songs.
Hope this helps. ;)
Not quite what I managed. First off use a SD memory card (slot behind the battery on zumo mine works with a 16Gb card),
theme I created a folder that for the files, on the Zumo when you browse files to play, maybe under playlist was a play all. Has been a min so :dontknow:I'm not 100% will test & get back:thumbup:
Hope this may help
On my Zumo 660
You go into the Tools
Select Media Player
At the bottom of the screen select Browse
At the next screen select All
You now get a screen with the option of Play All at the bottom
When you select this option the Zumo will load with all the songs you have loaded and it
will start playing the first song It will also show the total number of songs ie 1/2010
Notice on the right of side of this screen above the source button there are 2 options showing arrows 1 wii repeat the last song
The other allows you to Shuffle all songs
The Zumo supports MP3 music files M3U & M3U8 Playlist files
I have my music loaded as MP3 files copied from my Computer as files onto a 32gb card
I have over 2,000 music tracks listed
I have never bothered with playlist as you can select All, Select Album or Selected Artist which works for me
I agree with Eddie. For me his explanation is the easiest way to do it. I'm selective about what I've put on the SD card but don't give much of a rat's rump what plays or in what order so if I'm riding long distances I always select Play All. On shorter rides where I'm occasionally stopping I may select an album.
Thanks, it worked, Mike
Well it works but in between songs it briefly goes back to the radio then to the next song. Mike
