QUESTIONS ABOUT BLEEDING RTL BRAKES
Decided to bleed the brakes on our machine today because I felt that the pedal was a little "mushy". I had 2" of pedal movement before I felt any "braking resistance" so I thought their was air in the system. Pulled the front wheels and had the wife press on the pedal and I bled the left front 1st, then the right front next. Went to the rear and bled that caliper, had steady stream of fluid out of all 3 calipers. I gained 1/2" less pedal travel before resistance was felt(1 1/2"total instead of 2"). I just don't remember what the pedal felt like when it was new, when the pads, fluid, and hopefully no air in system. I d/n use a vacuum type bleeder, I did it "old school" and I've done ATV's, snowmobiles, motorcycles, cars and trucks, and got the feel I wanted. With this bike, I know it has ABS or a proportioning valve in the system. Can you get all the air out of the system by the way I did it or do you need a vacuum bleeder to do the job?? If so I will have to make a trip to HF sometime. So question is... On an RT with foot boards, how far does the pedal move before braking resistance is felt and do I need to use a vacuum bleeder to do the job properly? I have always kept the reservoirs full and have never let them go so low(pad wear) that I got a fault code or warning in the dash. Am I over thinking this too much? Come on you PROS out there, tell it to me straight. Mac:gaah:
wondering on the back brake
that back brake , is there an adjustment ? as in some sort of screw and nut adjustment ? getting near my bleed brake and replace fluid time !
