...put 20W50 Amsoil in a 2012 SE6 for an oil change. About 4.5 quarts of it... should we drain it and put in 10W40? Unsure about what to do....
Jim
Printable View
Jim
It probably isn't totally necessary but, I would change it. Excessively thick oil can cause real problems and with cold weather coming, it will possibly not allow proper lubrication when starting a cold engine. If you are not ever going to ride it in the cold, leave it alone until next spring.
should not hurt a thing as long as the engine and gearbox are lubricated and the clutch doesn't slip. Oil viscosity isn't as big a deal as people make it out to be.
rcturner is right about cold weather starting but as far as lubrication is concerned 20 weight oil should not cause a problem until temps are at or below freezing starting should not be a big deal at most temps at or above freezing
20W50 is as viscous (flowable) as 20W at low temps and thickens to a 50W as temps rise. So you are starting your cold engine with what amounts to a 20W in it. No problem.
Your fine till your next oil change. I serviced bikes for years in Texas with 20/50w castrol and it gets cold there like in your neck of the woods. If it makes you feel better warm her up a few minutes longer....:thumbup:
Amsoil is full synthetic oil ..........:lecturef_smilie: you could use their 20w/50 in the Artic and it would still flow ..........:roflblack::roflblack::roflblack::roflbl ack: .... Mike :bbq:
I agree with above posters.
