Do you need to pull both of these plugs for an oil change..?
Quote:
Originally Posted by
Maddoggie501
You are correct. Just did my 2016 RT. 45 Torx on main drain bolt and 6mm Allen on the clutch bolt.
Just curious because I only have 1600 mi. so far on mine and I too plan on doing my own oil changes (just can't part with $300. for the dealer to do it for me). So you will need to drop both of these plugs for an oil change, is this correct ..?
thanks
Where do you purchase these gold colored plugs at ..?
Ex-Rocket
If your successful in doing your own oil changes and are scared you might strip the drain plugs later during another oil change, many here have changed to the hex head drain plugs. I switched to Gold Plugs during my first oil change. So now you don't have to worry about stripping your drain plugs as a regular box end wrench will get the job done.
Do you know what size thread these oil drain plugs are ..?
