I replaced the battery in my 2010 rt the cables are tight on the battery but when I try to start it sounds like a loose connection click but not trying to start I am lost now any one help
Printable View
:shocked: I hate to ask this...
Are you SURE that the new battery was charged, and ready to be installed? :dontknow:
(They should be put on a trickle-charger overnight, before being pressed into service...)
Step one..... hook up a jumper to the system and if all is well look at the battery and or connections. Less likely but worth a check are all the fuses and relays, kill switch and any area recently worked on. From what you indicate I would suspect faulty connections or a battery with only a surface charge....:dontknow:
I bought a battery from batteries plus this morning I ck the voltage it was only 10 V hooked it up to a jumper and it started right away thanks for the tip back to basics was just right
:congrats: on getting "back on Three"! :thumbup::riding:
