RECOMENDATION WANTED FOR ADJUSTABLE FRONT SHOCKS
I have a 2016 RT Special and have added the Baha-Ron Sway Bar and a Laser Alignment.
I usually ride without a passenger and still have some diving on the front end around turns even with the new sway bar.
It was mentioned to me to add a set of firmer adjustable shocks and would like some help from you in choosing them.
Also, is a new toe adjustment required after replacement ?
Thanks for help with this.
Try placing more air in your front tires
Adding more air pressure to your front two tires can make a high difference in corning, especially in mountains riding! Something you may look at! You know cold weather air pressure is different from warm weather air pressure!
