I have 2015 F3S and considering adding a driver backrest. I also tend to ride with a passenger fairly often. My question for the group is does a driver backrest interfere with the passenger sitting position or ride in any way? Thanks for any input.
Printable View
The driver backrest makes a huge difference in comfort level for long rides. I have the Lamonster one, great thing about it is that when riding two up it takes a grand total of one second to remove it. If the passenger is small enough, then no problem just leaving it there, still a fair amount of seat room. But I'll remove it anyway, makes the passenger snuggle in a little closer if you know what I mean.
it is best to remove the driver's backrest when you are 2 up.
Size of BOTH passengers can have an effect on the comfort level. If we are dealing with large people (you are on your own defining that), a drivers backrest could be a problem for the passenger. No one wants to ride many miles feeling scrunched up.
We tried two up the first year with over 10K miles. Between my back and hip problems, and other problems which I will not mention, I determined we could no longer travel two up.
I was able to purchase a second Spyder, and that has solved OUR issues with the two up. :thumbup:
http://bakerbuiltairwings.com/prodde...p?prod=SPYF3BR
We have one that is easy install and is quick removal if desired.
