I need to change the max PSI setting for the rear tire. I read the manual and couldn't find how to reset if you want. For some reason it is set at 29 PSI max. Any help would be appreciated.
Printable View
Thought you just opened the app, go to rear tire and adjust the recommended/max setting?
Troop, Thanks. I figured out.
Just an addition, EdMat. Unless it has been changed, when you “save” the new settings, you have to position your phone next to the tyre stem for update and then press save. That is a pain on the rear tyre. I haven’t changed settings in years, which is why I don’t know if this step is still required.
Pete
Edmat explained well.
Pete, I will going out in about 1 hr and try all this stuff and report back if having to hold near sensor is needed.
I just finished setting and airing my tires. Didn't need to put phone next to sensor for any reason.
