How to get upgraded lower panel and oil filter cap
I change my own oil and do what ever maintenance I can on my 2011 Spyder RT. I'm not sure I've got this right but ...
I never received a voucher or notice for the lower panel update or the new oil filter can. I called BRP they said only the dealer can order the parts for me. The dealer said that they will not place the order without the voucher and the only way to get the new oil filter can was for them to preform an oil change ($120+oil+filter) or at the next scheduled maintenance visit ($230+oil+filter+parts).
Can this possibly be right?
First as mentioned you should have received the Voucher. There's a chance your dealer never registered your Spyder. You need the Voucher to avoid paying for the Panel parts.
Call another dealer, give them the VIN as ask if they could check if your Spyder is registered with BRP.
Now with regard to the panel, assuming you have the Voucher, my wife's Dealer was told by BRP Canada:
1) If you (Dealer) are doing an oil change install the panel no charge.
2) If the customer just wants the panel installed the dealer can charge for the installation.
3) If the customer wishes to install the panel themselves, give it to them.
She chose Option3. Its a straighforward install other than the 'freakin' mirror off/on.
Well worth the time and makes for an easier oil change. And you no longer have to remove the 'freakin' mirror.
John
