where/what is the easiest keyed power line to access in the frunk on a 2014 RTS?
Printable View
Did yours come with the accessory cigarette lighter adapter in the frunk? If not, then there should a plug dangling (just kidding) behind the knock-out plug.
turns out I did have my shop put in cig light adapter, but it is on a keyed circuit (or at least it is now as I moved the fuse from slot 7 to 6, or 8 to 7... whichever switches it from a live lead to a keyed lead)
I am assuming that I need to pull out the battery to get to the wiring leading behind that plug, or is there another way to get at those wires?
yes, I am lazy, and always looking for the easiest way to do things....:doorag:
I was able to tap into the outlet for the keyed power source
