I understand that the show chrome hitch will work for the RT, ST, RS, and GS. I know that the F3 looks totally different, but the swing arm on the F3T looks more similar to the previously mentioned bikes. So, will a hitch from a RT fit a F3T?
Printable View
Yes it will fit. The swing arm is the same.
The BRP hitch that I took off my 2013 RT LTD fits onto my F3T. As stated above the swing arm is the same. I just need to get that wiring harness set up for my RT622 trailer.
Thanks guys. I don't have a wiring harness on the RT, as I just use the hitch to attach my Doc Humphries rack. Thanks again.
OK I will bite. What's the difference? Same 10 pin connector with the same pinout. :dontknow::dontknow:
RT, ST and F3T are all the same.
Here is a picture of the connector to tap into from the F3 hitch instructions.
Here is the picture of the connector from the RT hitch instructions.
They used the same picture. :roflblack:
I was relying on info from Lamonster Garage which says that they are different wiring harnesses and are not interchangeable.
Cruzr Joe
