7 Attachment(s)
2011 RT Limited
I have a 2011 Can-Am Spyder RT limited. ( No luggage, no GPS)
The bike has approximately 30,500 miles on it. At 26,737 Miles the speedometer multifunction gauge was replaced by the local BRP/CanAm dealer (Marine World, Wichita KS).
At that time the odometer was reset to zero.
It is not possible to reset this odometer to its correct mileage per multiple dealership statements. I have the documentation from the dealer when this repair was made.
I have a clean clear no lean Kansas title.
The bike has newer tires
front (Nexen N'Priz AH5)
rear ( Federal FORMOZA AZ01)
I changed the oil and both filters when the new odometer was at 2300 miles in May 2022, Currently reading 3700ish. I'll provide exact mileage to those interested as it will continue to go up.
Baja Ron anti-sway bar
Baja Ron improved spark plugs and wires.
BRP comfort Seat
BRP Adjustable Side Wind Deflectors
BRP Xenon/HID headlight assembly kit (not installed)
Lid Lox
Lamonster NBV Highway brackets /Chevron pegs
Lamonster belt tensioner kit
Custom Dynamics Truflex High mount brake light
Additional amber rear turn signals
Generic LED front fender lights.
Baker air directional wings
RAM mount on dashboard in place of analog fuel gauge.(included)
Show Chrome wear bar accent
RIVCO BLACK EXPANDABLE TRUNK-MOUNTED LUGGAGE RACK.
Battery Tender Jr
Battery Tender Quick Disconnect USB Charger Adaptor
Nelson Rigg Can-Am Spyder Half Cover
$11,000.
Did you put 15" tires up front? And I'm assuming you had 14 " chrome wheels initially? Does it have the GPS nav?
1 Attachment(s)
As noted in the listing above, there is no luggage or gps. This has the 14-in aluminum rims. If Chrome rims were on it new, they were long gone when I purchased it in 2017
Needs a new garage to live in
If you were closer id consider this for sure
